1Back to top Go down   K100 exhaust clamps Empty K100 exhaust clamps Thu Jan 03, 2013 1:22 pm
ali2908
ali2908
Happy new year everyone Very Happy
What is the best way to fit the 4 clamps on the exhaust, I notice the clamps have 2 different part nos. how do you tell which ones go on the different pipes. When I bought the bike there were no clamps on them at all and I got a used exhaust which had the clamps but I can get 3 of them to stay tight but the 4th I cannot get access to tighten it. Do they have to be fitted in a particular way?
Any help appreciated
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
2Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 3:23 pm
twincarb
twincarb
You will find they only go on one way round which allows you to tighten them up! I found it out by putting them on and then couldn't tighten them up!
They are allocated exhaust 1 + 3 and 2 + 4 so if you put all 4 on with the like on 1+ 3 and the others on 2 + 4 and you can tighten them then you got it right first time around!!
Yamaha Thundercat
K100 exhaust clamps 169042K100 exhaust clamps 169034
3Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 3:27 pm
ali2908
ali2908
is the exhaust numbered from the front of the engine (1 being at the front)?
Does any one have any pictures of how it should be fitted?
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
4Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 3:33 pm
twincarb
twincarb
yeah thats right cylinder 1 is at the front and 4 is at the rear... I will see if I can fish out a photo ....
Yamaha Thundercat
5Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 3:34 pm
ali2908
ali2908
Cool thanks
Regards
Ali
1985 K100RS
2002 K1200 RS
6Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 4:31 pm
twincarb
twincarb
K100 exhaust clamps Exhaus10K100 exhaust clamps Exhaus11
These 2 images should help, they are taken from the Clymer manual... They certainly give a good idea of how they fit....
Yamaha Thundercat
7Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 5:01 pm
caferacer62
caferacer62
I found that if you put the clamps onto the muffler first you can see which way they go. That way you can see where the small tab that locates into a notch on the muffler tube goes. Then transfer them onto the header tubes and refit the muffler. Its a bit easier to fit the muffler back up with the clamps slid up the header tubes.
Try and put some sort of anti seize on the threads too, the heat does dry it out but at least it makes it easier if you have to undo them again.
Bert 2.0
K100 exhaust clamps 170874
8Back to top Go down   K100 exhaust clamps Empty Re: K100 exhaust clamps Thu Jan 03, 2013 5:17 pm
ali2908
ali2908
Ok guys that has been a great help will try again over the weekend.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
