1Back to top Go down   Wind screen screw designations Empty Wind screen screw designations Fri Mar 15, 2013 12:50 am
tio Jaimito
tio Jaimito
What is the size of the screw that holds the wind screen on the K100 Rs It looks to be 12mm long Pan head phillups , perhaps 4mm diameter. How is it classified? thread pitch, size. I want to pick one up and don't know what to ask for.
UJ
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
Wind screen screw designations K100_m12
Wind screen screw designations K75_po12
Wind screen screw designations Basil_10
http://www.nachicagonorth.com
2Back to top Go down   Wind screen screw designations Empty Re: Wind screen screw designations Fri Mar 15, 2013 1:02 am
Now when I think about it I am not sure if there are metric and imperial screw threads as I have never had to find out. I have always used the wire gauge system. I would say that it is a No8 screw.
Come to think of it there most likely would be a metric system after all the poms (english) used their own imperial sizes for everything else. I think just to be different
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
3Back to top Go down   Wind screen screw designations Empty Re: Wind screen screw designations Fri Mar 15, 2013 1:23 am
they are 5 mm metric
i have a bunch that i bought
mostly 20 or 25 mm long for the screen to be comfortable the nut section is about 8- 10 mm deep then you have at least 5 for the fairing then 6 -8 for the screen
hope that helps
i use stainless with stainless washers as well (add 1.5 mm)
Wind screen screw designations 2013-028
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OWind screen screw designations Au-log10
4Back to top Go down   Wind screen screw designations Empty Re: Wind screen screw designations Fri Mar 15, 2013 3:26 am
Toto_jp
You got me there Charlie looking at the photo of Gerty trying to work out what was out of place
it was the glass / lens cleaner just sitting in middle of no where Embarassed
K100 RS 1986
5Back to top Go down   Wind screen screw designations Empty Re: Wind screen screw designations Fri Mar 15, 2013 5:12 am
I use gutter bolts with hardware plastic covers.
6Back to top Go down   Wind screen screw designations Empty Re: Wind screen screw designations Fri Mar 15, 2013 5:31 pm
tio Jaimito
tio Jaimito
thanks Guys, 5mm it was. I do appreciate the help.
7Back to top Go down   Wind screen screw designations Empty Re: Wind screen screw designations Sun Mar 17, 2013 5:35 am
Ah Charlie playing with the blue tac again hey?
