1Back to top Go down   Oxford heated grips Empty Oxford heated grips Sat Mar 16, 2013 5:40 pm
ali2908
ali2908
Bought a set of the oxford touring heated grips, but not sure if they will fit. The diameter of the bars seems to be about 1.5 - 2mm larger than the new grips. Has anyone else had this problem or found a solution?
The throttle grip is the worst I have cut the original grip off and it is coated in plastic? see photo. would I rub it down with a file or something else?
Oxford heated grips Imag0110
Any help much appreciated.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
2Back to top Go down   Oxford heated grips Empty Re: Oxford heated grips Sat Mar 16, 2013 8:24 pm
Rendrag
Rendrag
Hmm, been a long time since I put my oxfords on, and I remember it being hell.. Clutch side was easy as (ended up taking it off and putting it back on with something sticky mixed with the soap, as it ended up turning too easily). Throttle was a massive PITA!. I ended up using the heat gun to heat the grip up quite hot, so it was soft, and then used a MASSIVE amount of dishwashing detergent to make it slide onto the plastic cage for the throttle. I seem to remember having two mates helping - one keeping the bike upright, and two of us pushing on that damned grip.
Make sure you have it lined up (rotation wise) before you start forcing the grip on - or you're pretty much screwed, and looking for a new grip, and a new cage for the throttle :-p
I understand that oxford finally got their controllers right, so you can set a specific temperature, and have it stay there (instead of only ever putting it on the lowest setting, and still burning your hands after a few minutes..) - do they have the same connections? A little white yeasu-power-style plug to each grip, and from the battery? Wouldn't mind retrofitting a new controller to mine if they're compatible
2000 VFR800
3Back to top Go down   Oxford heated grips Empty Re: Oxford heated grips Sun Mar 17, 2013 4:22 am
I was only just looking at Mr klompy's Oxfords this morning before pre departure, he may have some advice there.
I fitted Oxfords to my wifes Boulie last September, half hour job , with no technical issues.
unfortunately I'm one of those who get in and just do it, but don't always remember how i did it, just ask Mr k.
Our workshop went A1 last night.
hope all goes well.
Oxford heated grips 10_x_110
4Back to top Go down   Oxford heated grips Empty Re: Oxford heated grips Sun Mar 17, 2013 11:52 am
ali2908
ali2908
Rendrag here are pictures of the fittings and the controller Very Happy
Oxford heated grips Imag0113
Oxford heated grips Imag0112
Regards
Ali
1985 K100RS
2002 K1200 RS
