excorcist
excorcist
Hi, I have a k100 tank that i started to sand and like many other tanks, it has some pinholes around the bottom area next to the weld seam. I patched from the outside with a thin layer of jb weld, now I want to seal it from the inside. I was going to use a Motorcycle gas tank sealer kit, it comes with a cleaner, a prepper, and the actual sealant, Im wondering If I will have any trouble with any of the moving parts, Or how i Will be able to block off the two hoses on the left side of tank ( one is the fuel outlet, the other i believe is some sort of vacuum line?) So they do not get sealed shut. I can remove any parts that I need to,,, i was hoping someone has done this in the past, or at leat can provide some suggestions.
Here is the product I want to use:
http://www.summitracing.com/parts/kco-52000
Ned
Ned
Let me say that I have no experience with chemically welding/sealing bike tanks, but I have reservations with doing it in this case. I am not sure if the chemical sealant can match the expansion/contraction rates of metals such as aluminium and because of that I wonder if it is a permanent solution.
Without being an alarmist, the fuel tank on our bikes is above the engine, gets hot and it is directly above injectors and coils/spark plug wires...
Just a thought. I love to hear from people who have done it on bikes like the Ks.
BTW there are no vacuum lines in the tank. One is the fuel feed to the infector rail (high pressure; 36psi) and the other is a low pressure return from the fuel rail.
Ned
I have just had a friend here asking how to seal a tank which he spent over $100 on sealer alone to no avail.
This is the only stuff that I have had success with Permatex http://www.permatex.com/products/product-categories/specialized-maintenance-repair/professional-repair-systems/permatex-fuel-tank-repair-kit-detail
It is now nearly six years since the first repair which is still holding.
chrish8846
I used Eastwood gas tank sealer to seal 20 plus pin holes in my K75 tank, It's a 3 part process that ends up with you sloshing the sealer around in the tank as a final step. Worked great for me. I blew air thru the lines before the stuff got hard to make sure nothing got clogged.I called Eastwood before application and they said that it would be fine for a aluminum tank. Funny as it was I had no leaks before using a chemical stripper on the tank, I guess that BMW's primer and paint is a great tank sealer also.
Chris Hammond
1985 K100 RT sold
1992 K75RT still in Fixing mode
