Markzz
Markzz
Wanted: 130/90/17 back tyre and K100 offside pannier
Need these in the UK...pref round the corner from me in Belfast...
2Back to top Go down   Wanted: 130/90/17 back tyre and K100 offside pannier Empty just the offside pannier now... Wed May 15, 2013 4:38 am
Markzz
Markzz
Gotta Cheng Shin (Maxxis) so hopefully that'll work with the Metz on the front...still looking for an offside pannier...
@Markzz wrote:Wanted: 130/90/17 back tyre and K100 offside pannier
Markzz
Markzz
Also need a plug HT lead & still looking for a right side pannier in usable condition...
Ta!
the.postman
This is a bit scruffy but as it says "usable". Ebay
But why you would want to spray wd40 on the "hinges" is anybodies guess
1984 srx 600
1986 cbr1000f/h
walfish
walfish
Off side meaning Left or right?, I have a left side pannier available.
Wanted: 130/90/17 back tyre and K100 offside pannier Uk-log10 88 K 100  0033026
                            92 K 1100 LT  6455097
the.postman
ungaas wrote:Off side meaning Left or right?, I have a left side pannier available.
Off-side in "sunny Belfast" will be the right-hand when sat on bike
1984 srx 600
1986 cbr1000f/h
7Back to top Go down   Wanted: 130/90/17 back tyre and K100 offside pannier Empty yes right side one... Thu Jul 11, 2013 8:08 am
Markzz
Markzz
yes its the rhs pannier I'm after...thanks for the ebay link...no longer need HT lead - replaced that but still running v. lumpy under ~2500 RPM...any ideas...will trawl forum for tips...
Comberjohn
Comberjohn
Hi Markzz.
Good to see you are hanging in there.
A brief word of advice. You'll find lots more feedback to your posts if you tell us a bit more about your bike.
Model?
Colour?
Year?
Miles?
PHOTOS!
Regards your lumpy running, I would be looking for air leaks.
Is the oil filler cap tight?
Are all the blanking plugs on the 3 front TB's and the hose on the rear one?
Is the engine breather hose knackered and leaking?
Leaks on the inlet rubbers? Fiddily job to replace but can be checked first.
Don't let a pannier keep you off the road. Last two Saturdays I've covered 300 on both days doing the Irish Photo Rally.
You'd be welcome to join me if you can get on the road.
If you need some hands on help PM me and I'll see if I can come over and help you.
Meantime I'm heading off to Athlone in the morning for another photo on  my 84 K100RT that I bought for £380 last year. Easy.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
Brand new unused back tyre sitting in my shed.........BT as far as I remember.
Have Krauser K1 panniers....
In sunny Cork....
1983 K100RS 0011171 Fricka 606 Alaska Blue 29,495 miles Damn K Pox Its a Bat outta Hell Now 37,190 miles.
10Back to top Go down   Wanted: 130/90/17 back tyre and K100 offside pannier Empty poor running under 2k revs... Sat Jul 13, 2013 8:39 pm
Markzz
Markzz
hiya again comberjohn
thanks for the tips...i'll check 'em out
its a '90 K100LT with 57k miles
meant to say the poor running under 2000 revs only happens once the bike has warmed up...
yeh could do with a run out sometime...having to make do with another bike at the mo'
will pm ye re. having a look at it sometime...cheers
@Comberjohn wrote:
Model?
Year?
Miles?
11Back to top Go down   Wanted: 130/90/17 back tyre and K100 offside pannier Empty bits... Sat Jul 13, 2013 8:43 pm
Markzz
Markzz
thanks 92kk...am ok for a tyre now...does the k1 have the same panniers brackets as the k100?
not sure when i'll be in sunny cork or whether it'll be sunny when i'm there!...
92KK K100LT 193214 wrote:Brand new unused back tyre sitting in my shed.........BT as far as I remember.
In sunny Cork....
Glad you are sorted for tyres....I always put grip and wet weather properties ahead of long life. Have to with our weather. Having said that it is so so easy to change a rear wheel its not an impossible idea to have a rear tyre more suited to the hot dry weather of the last few weeks.
There are a number of different types of panniers and they seem to have different mountings. My brackets incorporate the rear indicators and both brackets were broken when I was hit from behind.
The panniers are large capacity, take a full face helmet as does my top box. I plan on keeping the top box because it is quickly demountable with the top box key and is extremely useful.
Krauser told me my panniers were K1 type and I did see a sticker with this label inside them.
Comberjohn
Comberjohn
Hi markzz.
Based on the additional info about happening when warm, I would be thinking of the Hall effect sensors.
They live behind the 'T' shaped cover on the front of the engine, so easy to get at. They trigger the ignition. Not unheard of for them to play up when warm.
If you do a search on the forum you will hear from others who have gone before you.
Basic way of checking them is to take off the cover and heat them with a hair dryer on a cold engine  without starting.
Then start up and see if the fault is there.
Replacements always on eBay.
Need to get you on the the road for the get together that Olaf has in mind.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
14Back to top Go down   Wanted: 130/90/17 back tyre and K100 offside pannier Empty hair drier test...ok Fri Jul 26, 2013 10:46 am
Markzz
Markzz
Hi John, eventually managed to have a go at the hair drier test - seems to run ok when I heated up the Hall sensor...will check out yr other suggestions....cheers, Mark
I've moved this post over to...
https://www.k100-forum.com/t6377-lumpy-runningcould-be-electrical
Markzz,
You need to get up and running!!!
We are getting impatient for a little get together. You have GMcQ and Comberjohn for excellent company up there.
My K came from Darren 08 [he still has a bike]....who hailed from Lisburn. Bjorn is due back from holidays soon and 88KE is up for a meet. So is Corkboy, as is Sgmayhew, add Ringfad and Tom Foley apologies for any omissions.
Add HoverK100.
92KK
Markzz
Markzz
yeh jeez dont I know it! been busy so must get this bike sorted soon!
