1Back to top Go down   Ignition trigger position Empty Ignition trigger position Fri May 31, 2013 7:37 pm
LifeGuard
LifeGuard
What are the consequences if you litle move the backplate in ignition trigger?
Is this a kind of ignition advance?
Ignition trigger position Triggerv
http://tchorzewski.net
2Back to top Go down   Ignition trigger position Empty Re: Ignition trigger position Fri May 31, 2013 8:08 pm
LifeGuard wrote:What are the consequences if you litle move the backplate in ignition trigger?
It is the ignition advance adjustment, you can move it but obviously some care is required.
Ignition trigger position K-dogs10
