1Back to top Go down   Inside Diameter of Cooling Hoses Empty Inside Diameter of Cooling Hoses Tue Jun 25, 2013 9:05 pm
Keg
Keg
Hi all,
I am away from my Bike right now and am wanting to order my aftermarket Digital Speedo. I need to provide them with the Inside Diameter of the Cooling Hose I intend to put my Temp Sensor into. This sensor is just a T Piece that you cut the hose and insert into both sides. I have been scanning the web without luck. The Hose I was looking at installing the T Piece in is either the hose from the left hand top of the Radiator down to the block BMW Part # 17 12 1 460 278, or the other hose that goes from this hose across the rear of the radiator towards the Thermostat BMW Part # 17 12 1 460 416. If anyone can assist it would be greatly appreciated as I can then order and have it at home when I get back in 7 days. Bike is an 87 K100RS
2Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Tue Jun 25, 2013 9:16 pm
You dont put the temp sender into the hose across the back of the radiator as it only has a flow when the engine is warming up. If you put it in the hose from the temp sender to thr left top of the radiator be prepared to see the temp going up and down like a yo yo. best place to put it is into the water pump housing next to the oil sender switch (there is a small socket head bung). That is where BMW put the senders for the factory gauges.
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
3Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Tue Jun 25, 2013 9:58 pm
Keg
Keg
Thanks for the reply Rick. As I said I am not near my bike currently. I might do some investigation into the original Temp Sensor and see if it can be adapted to provide the signal required for the new unit. The unit I am fitting will be a Trail Tech Vapor Stealth with the Dashboard adaptor. Might order for now without the Temp Sensor until I can finalise what type of install I want to use.
4Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Wed Jun 26, 2013 3:13 am
Erman
Erman
Why does the Vapor need ID of the coolant hose?
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
5Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Wed Jun 26, 2013 3:56 am
It is for which fitting to use for the temp sensor.
6Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Wed Jun 26, 2013 5:16 am
Erman
Erman
Ah. Simple answer that I did not think about. My thoughts went towards an algorithm to detect something in relation to the ID of the hose.
Bikes:
1984 BMW K1000RS
7Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Mon Sep 30, 2013 6:52 pm
ausbrick
ausbrick
Don't cut a hole in rad hose  find an electric type sensor set up .Those tee type mounts that fit in the hose are a breakdown waiting to happen.
8Back to top Go down   Inside Diameter of Cooling Hoses Empty Re: Inside Diameter of Cooling Hoses Mon Sep 30, 2013 10:25 pm
japuentes
japuentes
@ausbrick wrote:Don't cut a hole in rad hose  find an electric type sensor set up .Those tee type mounts that fit in the hose are a breakdown waiting to happen.
I agree.
Best regards
JAP
Inside Diameter of Cooling Hoses 2854237993 1988 K100RS SE/ABS
