Gacknoops
Gacknoops
Per the topic, when I let off the throttle at any speed there's a rattling or clatter coming from somewhere around my right foot peg. It also makes a more hammering sound at higher torque situations like leaving a stop sign or climbing a hill in too high a gear. This noise is present even when the bike is cold but does seem to get slightly louder as the bike warms up.
I'm an experienced technician so please feel free to answer in whatever technical terms you need to explain your diagnosis.
hmmm
monkey nuts ?
that's the rubber insulators between the altenator and the drive gear
just behind - inside the right foot
Gacknoops
Gacknoops
Is that something that I could let go until winter?
K100RS
year, 1989
84,000 miles.
Gacknoops
Gacknoops
Thanks Charlie!
I just did the same google search I've been doing but added "alternator" and BOOM! Apparently it's the most common complaint in the K series.
Thanks again for your help!
Brian
K100RS
year, 1989
84,000 miles.
you risk braking the bell housing that connects to the altenator ...but more importantly the drive mechanism , its shaft and sprag clutch (used in starting ) along the same auxiliary shaft
doesn't take long to do ..but could save a major pull down to do the other repair
Gacknoops
Gacknoops
I'm googling the procedure as we speak (type).
Thanks again!
K100RS
year, 1989
84,000 miles.
Monkey nuts or the uni joint is shagged.
billy_k100
billy_k100
any idea what the problem area was? My 86 K100rs has very similar symptoms
I was going to say uni joint too.  They can clatter a bit on high torque loads before failing completely.  Had it happen myself.
Clatter/Rattling when throttling down. K-dogs10
billy_k100
billy_k100
AL-58 wrote:I was going to say uni joint too.  They can clatter a bit on high torque loads before failing completely.  Had it happen myself.
Thanks. As I am going to dissemble the drive train, when signs should I look for when inspecting the drive shaft uni-joint?
Mine was obvious as it failed completely.  I'd be checking for any play in the universal joint.
