1Back to top Go down   OEM Handlebars for a 1988 K75S Empty OEM Handlebars for a 1988 K75S Sun Aug 11, 2013 1:03 am
Bigdibbs
Bigdibbs
Does anyone have an image or can tell by my pic if the handlebars I have are original for a 88' K75S?  The original owner put all sorts of bar risers on the bike, which I have taken out but the OEM brake line and the steering cover/switch hubcap doesn't really fit.
OEM Handlebars for a 1988 K75S FrRhr8
Tried to load an image, but it is not working so maybe someone has one I could see.  Any tips on loading images? Hosting didn't work nor did entering my flckr url
Last edited by Bigdibbs on Sun Aug 11, 2013 1:08 am; edited 1 time in total (Reason for editing : Trying to post a picture.)
2Back to top Go down   OEM Handlebars for a 1988 K75S Empty Re: OEM Handlebars for a 1988 K75S Sun Aug 11, 2013 1:34 am
Here is a pic from a sales brochure hope it helps.
OEM Handlebars for a 1988 K75S Image111
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
3Back to top Go down   OEM Handlebars for a 1988 K75S Empty Re: OEM Handlebars for a 1988 K75S Sun Aug 11, 2013 3:23 am
Hi Bd,
My second 75S came fitted with C bars and the S bars are in a box.  Give me a couple of days and I will get a photo up on the forum for you.
Dave.
4Back to top Go down   OEM Handlebars for a 1988 K75S Empty Re: OEM Handlebars for a 1988 K75S Sun Aug 11, 2013 3:57 am
MikeP
MikeP
The K75S crash-pad/cover should look like this:
OEM Handlebars for a 1988 K75S BMW%20K75%20%28394%29-L
It's quite a common mod that owners swap the K75S bars for K75C ones. The latter have a very similar width (just about an inch wider over-all) but are about 3 inches higher.
The simplest way to determine whether yours have been swapped is to feel the point where the bars curve. The 'C' bars are bent:
OEM Handlebars for a 1988 K75S DSCF2753-L
Whereas the 'S' bars are cut and welded at the bottom (ignore the apparent width here, the grips have been slid to the end prior to removal):
OEM Handlebars for a 1988 K75S BMW%20K75S%20%28117%29-L
The bars have different crash pads and the brake hose from the master cylinder is longer on the 'C' to accommodate the extra height.
1992 K1
5Back to top Go down   OEM Handlebars for a 1988 K75S Empty Thanks Wed Aug 28, 2013 9:07 pm
Bigdibbs
Bigdibbs
Those pics were perfect and confirmed that I do have the OEM S bars, thank you very much for the information.  I am not sure why the crash pad was cut, I will probably just replace that since the previous owner had cut it down.  Replacing the brake hose was a tight fit, but it works with no leaks so I am assuming it is all good.
Matt207
Matt207
Ciroprautor says I need an uptight riding position
Have a 1991 k7s
So I assume I need to order cables for an rt
Do I Need to cut  or modify any electrically?
                 Matt in glendale  Az
Spelling by my iAdiAd
7Back to top Go down   OEM Handlebars for a 1988 K75S Empty Re: OEM Handlebars for a 1988 K75S Tue Nov 19, 2013 7:23 pm
The electrical cables on the switch blocks are all the same length so you don't need to do anything there
8Back to top Go down   OEM Handlebars for a 1988 K75S Empty Re: OEM Handlebars for a 1988 K75S Tue Nov 19, 2013 8:55 pm
Matt207
Matt207
Thanks for your quick reply Rick. Think I'll get started right away, don't think I could handle the "s" configuration on a trip from Phoenix to LA. As I've gotten to know this bike fairly well, I really didn't want to sell it
Regards, Matt
9Back to top Go down   OEM Handlebars for a 1988 K75S Empty Re: OEM Handlebars for a 1988 K75S Tue Nov 19, 2013 9:10 pm
S cables will work with C bars.  Depending upon the brake line setup you may need to use a different line from the front master.  However, many times, by loosening the banjo bolt under the front master and changing the angle you can use the old one.
