1Back to top Go down   Installing spotlights on a K100 Empty Installing spotlights on a K100 Sun Aug 11, 2013 8:41 am
coopz
coopz
Hi everyone thinking of installing two spotlights under fairing on a bar arrangement. Cannot find previous thread but can someone show me a simple route for wiring relay etc using headlight wiring as a source with a simple switch on dash thanx in advance Coopz
1985 K100 RS
2Back to top Go down   Installing spotlights on a K100 Empty Re: Installing spotlights on a K100 Sun Aug 11, 2013 10:50 am
coops ...you can find just about everything here by using the "search"  function
just type in the subject and there will be a few links
not hard at all
 so by typing in "installing relays"
I got this .....   http://www.google.com/search?q=installing+relays+&sitesearch=k100-forum.com&selected_id=-1&tid=a93748479969d10d067486ef7806a266
here's what I found which could be interesting
https://www.k100-forum.com/t702-headlight-upgrade-experiances
 you will find a circuit or two in there as well
if using the headlight connector to "pick off "  the colours are yellow white and brown
good luck
3Back to top Go down   Installing spotlights on a K100 Empty Re: Installing spotlights on a K100 Sun Aug 11, 2013 9:23 pm
Yeah bought back some memories that thread so please dont think that is the normal here but far from it.
With regard to the lights the one thing to be careful of is dont exceed the capacity of the alternator so you should not go any higher than 55w for each light or the alternator will get overloaded and the voltage drops off and so does the light output. The new LED lights are good for the application.
4Back to top Go down   Installing spotlights on a K100 Empty Re: Installing spotlights on a K100 Sun Aug 11, 2013 9:42 pm
Reopropf
Reopropf
These are LED's from Rigid Industries.
Installing spotlights on a K100 Photo13
5Back to top Go down   Installing spotlights on a K100 Empty Re: Installing spotlights on a K100 Sun Aug 11, 2013 10:33 pm
I've got a pair of 35w HID driving lights waiting to go on.  Light is not a problem.
+ another motorcycle and sidecar
Installing spotlights on a K100 K-dogs10
6Back to top Go down   Installing spotlights on a K100 Empty Installing spotlights on a K100 Mon Aug 12, 2013 5:20 am
coopz
coopz
Many thanks for info all taken onboard, this is a bloody good forum thanx Coopz:D
1985 K100 RS
7Back to top Go down   Installing spotlights on a K100 Empty Re: Installing spotlights on a K100 Mon Aug 12, 2013 6:46 am
did a bit of editing coopz
added your new subject to the old one
just to keep it all tidy .....cheers !
