1Back to top Go down   Measurements Please. Empty Measurements Please. Thu Aug 22, 2013 3:00 am
Ghost who rides
Ghost who rides
Hi guys , I need help with a couple of measurements re. the rear ducktail piece.
  I am making up my own carrier/ topbox mount and would like to know the dimensions
  of the mounting bolt pattern. I have drilled the upper frontmost holes with an angle
  drill through the strengthened bosses but have to drill the rearmost two from the outside
  and would like to get as close as possible to those bosses. I measure 168 mm centres for
  the front 2, so need dist between the rear 2 and front to back dist each side.
   Hope that's clear, thanks, G
2Back to top Go down   Measurements Please. Empty Re: Measurements Please. Thu Aug 22, 2013 4:28 am
158mm between the rears and 136mm front to back.
3Back to top Go down   Measurements Please. Empty Re: Measurements Please. Thu Aug 22, 2013 4:35 am
good luck gordo
have to do similar soon ....pics please !!!
4Back to top Go down   Measurements Please. Empty Well!!!! Thu Aug 22, 2013 10:40 am
Ghost who rides
Ghost who rides
By my reckoning that took just less than one and a half hours for an answer to my problem!
  Thanks Bikerboy.
  This forum is FANTASTIC.
  Crazy Frog , you have a Gold pass to the Pearly Gate!
  A pic.
Measurements Please. 31410
This is BERT.
 Friends of mine have an animal sanctuary and care for injured/orphaned creatures.
This is BERT, A baby TawneyFROGmouth.
5Back to top Go down   Measurements Please. Empty Re: Measurements Please. Thu Sep 05, 2013 12:30 am
Ghost who rides
Ghost who rides
Thanks to Bikerboy I got the mounting holes drilled then set about carving a piece of 4mm aluminium plate.
Boy I miss the fully equipped engineering workshop 60 metres from my home in Tassie!
Measurements Please. 2013-010
Various slots for bungees or straps. Tri oval cutout for the roundel is an attempt to mimic the exhaust end shape.
Measurements Please. 2013-011
  Kick up at the rear so swag is located prior to strapping on. This will become the base for an expandable top bag when the swag is not required.
Cheers, Ghost
6Back to top Go down   Measurements Please. Empty Re: Measurements Please. Thu Sep 05, 2013 1:15 am
nice job gordo
