1Back to top Go down   Shock Absorbers K100 , K75 Empty Shock Absorbers K100 , K75 Sun Oct 06, 2013 4:46 am
Tom GKR
Tom GKR
G'day All, This topic has most likely been covered before so apologies for any inane questions.In view of Rick-meister's recent shockie failure and other similar failures, what is a good replacement shock.
Is it worthwhile getting a used shock for rebuilding???? What do the valued members of the forum think. Thank you all. Cheers Tom
2Back to top Go down   Shock Absorbers K100 , K75 Empty Re: Shock Absorbers K100 , K75 Sun Oct 06, 2013 5:18 am
MikeP
MikeP
The OE unit isn't really intended to be rebuilt, although there are a small number of specialists who will do it it's often cheaper to buy a decent replacement.
Possibly the best value for money in terms of performance is the RAM unit made by Realm Engineering.
http://www.realmengineering.com/page7.html
I've only ever used their shock on one bike (so far) but it seemed every bit as good as suspension that costs four times the amount.
1992 K1
3Back to top Go down   Shock Absorbers K100 , K75 Empty Re: Shock Absorbers K100 , K75 Sun Oct 06, 2013 5:51 am
@MikeP wrote:The OE unit isn't really intended to be rebuilt, although there are a small number of specialists who will do it it's often cheaper to buy a decent replacement.
Yep +10
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
4Back to top Go down   Shock Absorbers K100 , K75 Empty Re: Shock Absorbers K100 , K75 Sun Oct 06, 2013 6:11 am
yep have only heard good reports from them
good on beachcomer
just on a side note ...my "fox" twinclicker isn't busted ...got a final drive seal issue
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OShock Absorbers K100 , K75 Au-log10
5Back to top Go down   Shock Absorbers K100 , K75 Empty Re: Shock Absorbers K100 , K75 Sun Oct 06, 2013 4:29 pm
Comberjohn
Comberjohn
I agree that the Realm shock is the one to buy if you have the readies.
An alternative, if you are watching the pennies, is to rebuild the original with a new Bilstein damper. James Sherlock in the UK are offering them for £112.80. Sherlocks
Don't need a specialist to rebuild it, just a big hammer and a small cold chisel. I borrowed a pair of small spring compressors to put it back together.
The result is ok. 'You pays your money...'
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
6Back to top Go down   Shock Absorbers K100 , K75 Empty realm shock Sun Oct 06, 2013 4:57 pm
colinijohnson
colinijohnson
bought - very happy....with progressive springs too - transforms the bike
Colin
7Back to top Go down   Shock Absorbers K100 , K75 Empty Re: Shock Absorbers K100 , K75 Sun Oct 06, 2013 11:05 pm
@Comberjohn wrote:I agree that the Realm shock is the one to buy if you have the readies.
thanks for the tip cj
could be a winner idea for those lightening up the rear end  and working within a budget
