1 swapped FI- was ok, now running rough again PROBLEM SOLVED !!! Mon Oct 28, 2013 9:23 am
colinijohnson
I limped the bike to my mechanic today with a load of "spares" I'd purchased. Problem solved - injector no 4 was blocked. Upon closer inspection, the fuel rail was rusted inside.
The rail was cleaned up and for good measure the fuel lines and filter inside the tank replaced...(exterior ones done last year). I'd brought replacement injectors a few weeks ago, as mentioned eleswhere on the forum, ....f27 delphi Buick Ford Lincoln types with the same spray pattern. They cost £12.50 each off Ebay!!! here's the link, they post worldwide.
http://www.ebay.co.uk/itm/181072846468?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
All 4 were replacesd and the thottles balanced again.
Well I can honestly say the bike rides like new and like never before - no hesitation, repetition or deviation- Smiles all round and thanks to this forum and Phill at Allbikes.
I'm sure replacing the F1, battery and coils + cleanining the connections probably had some impact too - but the rusted fuel rail & blocked injector was the main culprit.
I was getting 40mpg, and will post improvements I'm sure will materialise.
Colin
Can someone please point me in the right direction???
I serviced the bike - swopped the silencer to a Motad and put on new studs.- injectors cleaned - ALL connections deoxited (except airbox)- has a new temp/fan switch and the TB's have been balanced.( there are no leaks here and the breather hose has been renewed)
I've always had a problem with cold starting (except in summer) - having to feed the throttle and rev. But since the silencer was swopped it ran rough - so i bought a new Fi for £130 (under the seat) - for 3 days it was up to 95% power and good - now its back to 80% and I have to keep revs up.
I do know the battery is not keeping its charge, and will buy a new one this week - but after reading various posts Im leaning towards the FPR or the airbox.
Has anyone else experienced these issues?? I get the impression she is runing rich from the plugs i changed. Yesterday I cleaned EVERY connection under the tank except the airbox.
Many thanks
Colin
Last edited by colinijohnson on Mon Nov 11, 2013 1:35 pm; edited 2 times in total (Reason for editing : just me)
