1Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 12:38 am
RSMITH
RSMITH
Hi All,
took my left switch apart to sort out the clutch start lock out switch and I found a piece of wire had been twisted onto the bridge part of the terminal behind the brown and blue wire and that the other end of it had been forced againts the handlebar as if make some sort of earth contact?
why would this have done? everythings seems to work ok? could be to somehow "cancel out" the self cancelling of the indicators? i am not sure that my bike has this feature? its an 84 k100?
1984 K100RT (Trans Karoo Express)
Set phasers to "fail"........................ If I were Britianna I would waive the rules.........
chasing echo's mostly.................
2Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 2:33 am
Cant imagine why an earth would be wanted there all it would serve to do is make the indicator work all the time. I certainly would not leave it there.
All the K models have self cancelling indicators and depending on speed will cancel at either 220metres or 10 seconds, I think the speed is about 30MPH.
3Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 3:22 am
RSMITH
RSMITH
i didnt know all them have self cancelling indicators?
mine does not self cancel- maybe this is what the small wire is for?
dunno will take it out and try?
how does one add pictures to the posts?  i have taken a picture of the wire in question and cannot seem to be able to post it
4Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 3:47 am
This link will explain how the pictures work https://www.k100-forum.com/t998-posting-pictures-and-movies
This is the layout of the relay box under the rear of the fuel tank SMALL WIRE ON LEFT SWITCH Relay_10
You will be able to see if the relay is there.
5Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 5:42 am
RSMITH
RSMITH
C:\Documents and Settings\z151518\Desktop\Photo0065.jpgSMALL WIRE ON LEFT SWITCH C:\Documents and Settings\z151518\Desktop\Photo0065
6Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 7:27 am
you need to drop-share  the link to an already hosted picture somewhere on the internet ...rather than from your desktop pc
like dropbox ...servimg and many others
hope that helps
7Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 5:08 pm
Ghost who rides
Ghost who rides
Does your Speedo work? Self cancel needs the speed reading to calculate the cancel, I think.
8Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Tue Nov 26, 2013 6:17 pm
FYI: When the blue/brown wire is grounded by the left turn switch it sends a ground to the flasher relay to turn on the left turn signal.
9Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Wed Nov 27, 2013 12:49 am
RSMITH
RSMITH
 Speedo does work,
dunno put everything back together last night and all working?
will take it out for a ride this weekend and see what may have changed?
10Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Fri Dec 20, 2013 8:09 am
RSMITH
RSMITH
now really wierd, '
i have to really press the indicator switch to get it to come on?
like it is jammed up or the contacts are just not touching nicely?
everything was good?
what could I try?
11Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Fri Dec 20, 2013 9:30 am
I had one like that on the K100 when I first got it and the switch was just plain worn out.
It could just be dirty and need cleaning or if it has overheated at some stage the contacts get hot and sink back into the plastic insulation. I tried building up the contacts with some solder but had limited success and ended up replacing the complete block when the dip switch started acting up.
At least we can still buy new switches I have been trying ti get a left switch block for my Z1300 Kawasaki for the last 2 years, all thats available is used and most are worse than mine.
12Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Fri Dec 20, 2013 9:43 am
RSMITH
RSMITH
Eish!
( local lingo that the situation is so bad that all is dire and will be in vain)
will have a look at as per what you have recommended
thanks
13Back to top Go down   SMALL WIRE ON LEFT SWITCH Empty Re: SMALL WIRE ON LEFT SWITCH Mon Dec 23, 2013 2:03 am
RSMITH
RSMITH
sorted!
gave the switch a clean out as best I could, working as it should now
cheers!
