mleikarnes
mleikarnes
How to build a sidecar in aluminium!
Model for the sidecar in copper, made from old electrical wire (my dad is an electrician...)
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_1348_zps970130a5
Thees pictures are from the winter 2004/2005 when we first built the sidecar for the SV1000S and five years later we changed it over to the 1984 K100
Building a BMW K100 with aluminium sidecar & single sided front suspension. IM001365_zps22297366
Building a BMW K100 with aluminium sidecar & single sided front suspension. IM001366_zps77e1f275
Building a BMW K100 with aluminium sidecar & single sided front suspension. IM001384_zpseaa1ead2
Building a BMW K100 with aluminium sidecar & single sided front suspension. IM001418_zps182381d3
Building a BMW K100 with aluminium sidecar & single sided front suspension. IM001422_zps4aab0b44
Building a BMW K100 with aluminium sidecar & single sided front suspension. IM001423_zps96889575
Building a BMW K100 with aluminium sidecar & single sided front suspension. Skrapbilder001_zpsb26418ca
Building a BMW K100 with aluminium sidecar & single sided front suspension. Skrapbilder004_zps5b69e1a3
Building a BMW K100 with aluminium sidecar & single sided front suspension. Deiverse162005-05-16_zpsb1c5eacf
Building a BMW K100 with aluminium sidecar & single sided front suspension. Bilde002_zps5178592e
Then we jump foreward to 2010 and the building of the K100 with this sidecar!
A moose wanted a taste of a K100:
Building a BMW K100 with aluminium sidecar & single sided front suspension. 66_1051714485_zps7c7c7e9e
Building a BMW K100 with aluminium sidecar & single sided front suspension. 66_-1774986085_zps578af7dc
After some maintenance it finally started and we got to testride it to check if it was okay!
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_9196_zps8f2b12dd
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_9197_zpsf5833822
It didn't run like it should, it had been on the side on a pallet half the length of Norway in a lorry...
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_9531_zpsc73d06cf
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_9532_zps388689c5
Then we startet thinking about the construction of a new single sided suspension, we had one from the SV1000S, but we soon realised that it wouldnt fit the K100, so a new idea was forming in my dads head. All the templates were made out of wood with a staplegun and then we just bent pipes that matched the templates so and so... The wishbones length and placement was desided by mounting the tire to a table and then moving it around until it was in line and the lengt fitted the rest.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0346
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0347
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0351
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0354
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0349
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0359
Templates for wishbones
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0360
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0361
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0363
First try on making wishbones:
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0364
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0365
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0366
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0367
http://s1139.beta.photobucket.com/user/Leikarnes/media/LEIKARNES-MC/Leikarnes%20MC-ombygging/BMW%20K1100%20sidevogn%20og%20navstyring/Mobilbilde0368.jpg.html
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0369
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0370
Single sided suspension done!
Building a BMW K100 with aluminium sidecar & single sided front suspension. PB082574
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0383
The pipe bending machine we use, my dads work has much good tools!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0390
Turning a new spacer out of aluminium for the rear wheel!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0388
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0386
Building a BMW K100 with aluminium sidecar & single sided front suspension. PB132581
Building a BMW K100 with aluminium sidecar & single sided front suspension. PB132585
A big spacer! From BMW K100 4 bolt to BMW E30 5 bolt!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0394
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0395
Building a BMW K100 with aluminium sidecar & single sided front suspension. PB182595
Bike and sidecar mounted.
Building a BMW K100 with aluminium sidecar & single sided front suspension. PB192603
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0408
Testdrive!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0410
Welding all around.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0412
Acid treatment and polish of all parts.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0416
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0417
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0418
GSXR 750 fearing:
http://s1139.beta.photobucket.com/user/Leikarnes/media/LEIKARNES-MC/Leikarnes%20MC-ombygging/BMW%20K1100%20sidevogn%20og%20navstyring/Mobilbilde0426.jpg.html
Before final paint and fishing touches, one year from this date.
Building a BMW K100 with aluminium sidecar & single sided front suspension. P1222660
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0750
We bought a K1100 which looked like something a crazy man could have designed and made, we stripped it and changed engine with the K100.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0752
Eskortekåpe fra Den Danske Garde... Til salgs dersom noen er interessert???  :lol
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0754
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0716
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0717
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0718
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0719
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0721
Frame out, sandblasting next!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0724
Engine and final drive out
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0727
Lowrider on paint storage.
bike #2
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0764
Store hauger med deler...
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0774
Steamwashing next
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0779
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0780
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0781
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0783
After some steamwashing:
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0784
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0786
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0787
K1100 engine painted!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0789
First layer on.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0755
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0756
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0757
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0760
BLUE!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0767
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0768
Our make up paintbooth!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0763
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0769
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0770
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0771
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0772
Putting the bits back together! the new engine is 14 years newer!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0790
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0791
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0792
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0793
Biltemas 4" headlights.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0819
TT-bars!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0822
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0821
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0820
"Dash"
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0825
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0827
Digital speedometer!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0828
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0830
Fiverglass mould for new saddle and rear end
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0836
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0837
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0838
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0838-001
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0840
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0841
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0842
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0844
Leikarnes MC
Rebuilding, custom work
1984 - BMW K100RT under long time rebuilding to K100GS
1984 - BMW K100RS with 1998 K1100 engine under building to single sided front suspension and sidecar.
1990 - Suzuki DR750 Big
1990 - Suzuki GS500E Cafe Racer
2011 - Triumph Tiger 1050
2003 - Honda Varadero XL 125 Street fighter
My Norwegian blog translated to english
https://translate.google.no/translate?sl=no&tl=en&js=n&a
mleikarnes
mleikarnes
More fiberglass and some other stuff!
Rear end nearly done!
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3635_zps82a4281e
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3637_zps44f99592
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3638_zpsd79659ab
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3639_zps1f95fa9b
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3640_zps15fa9d05
Making mould for the saddle
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3641_zpse0066ca3
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3642_zps5307e4dc
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3643255B1255D_zpsb3e1c23e
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3644_zps47d144d0
Making a hugger at the same time.
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3645_zps2a85fed3
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_3646255B1255D_zpsf6743871
New fearing underway, some GSXR 750 still left.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0854_zps00e99ec7
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0855_zpsc3adba58
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0856_zpsf47e3b89
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0857_zps760899f3
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0858_zpsa1f7de49
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0860_zpsa385ed14
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0861_zps75d27c89
painting!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0864_zps6977ad9a
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0865_zps15d3cc42
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0866_zps18b72929
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0869_zps94d1e10b
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0870_zps31df5a32
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0871_zpsffc4135a
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0872_zps8d4760bc
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0873_zpscd994e47
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0875_zps5928dfa9
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0876_zps20833692
Finished painted!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0879_zpsa0e5283e
Aluminum upper fork legs
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0882255B1255D_zps6fbc072d
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0883255B1255D_zps501970c1
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0887_zps18c5ec1d
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0894_zpsbd814f95
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0896_zpsd82e8062
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0901_zpsa03b4192
Hugger:
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0902_zpsb3f94047
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0906_zpsfc9e159a
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0907_zpse4f0d100
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0908_zpse085d0b5
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0915255B1255D_zps8c7fb153
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0916255B1255D_zpsd516acf6
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0918255B1255D_zpsa51e9ec5
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0919255B1255D_zpsa882f1c1
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0920255B1255D_zps6d62f2de
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0923255B1255D_zps61d5488e
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0924255B1255D_zps0d37499a
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0925255B1255D_zps3a16288d
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0927255B1255D_zpsa91cb81f
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0938255B1255D_zps5ff15638
Exhaustpipe from old oil filters and drainage pipes in stainless steel.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0946255B1255D_zps00eda2b4
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0947_zps0c9e79a4
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0948_zps4f3d8b24
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0949_zps4e3c2f4d
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0950_zps857367ef
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0951_zpseefd5d6f
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0952_zps943c21ef
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0953_zpse60832b1
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0954_zps4f599d7e
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0955_zps6e22c244
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0956_zpsd7a00ba1
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0957_zps05f6aff8
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0958_zps8d019ab6
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0959_zps57f27336
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0960_zpsbd897769
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0961_zpsd76747ac
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0965_zps1e30c93f
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0970255B1255D_zps7b9e38ca
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0971255B1255D_zps21df03fb
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0972255B1255D_zps447ec985
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0973255B1255D_zps951c466c
New saddle!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0974255B1255D_zps413e605f
Homemade foot rests, some GSXR750 parts here too
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0977_zps228422c4
Size differense!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0980_zps21562082
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0984_zpscb207d14
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0987_zps17723f50
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0988_zps739fa158
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0994_zps5bfb7704
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0995_zps63813366
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0996_zps9958f687
Finito!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0998-1_zpsfce9a510
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde0999_zps75f50185
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde1000-1_zps5474554b
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde1001-1_zpsc90c6ad5
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde1002-1_zpsce187b23
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde1003_zps73a7215c
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde1004_zpsc98a62f3
Building a BMW K100 with aluminium sidecar & single sided front suspension. Mobilbilde1007_zps4180cd1e
Leikarnes MC
JGT
JGT
That is amazing!!! John
1992 K75
walfish
walfish
Some excellent ideas there, well done, I'd love to hear the exhaust.Any chance of a video.
 Building a BMW K100 with aluminium sidecar & single sided front suspension. 22936
Building a BMW K100 with aluminium sidecar & single sided front suspension. Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
May I merely say.......WOW!
mleikarnes
mleikarnes
Thanks!:-D
This is the only video I have I think... this is in January this year. As its sold now I cant get a new video :O
Leikarnes MC
Saxon7 wrote:May I merely say.......WOW!
KKlompy Building a BMW K100 with aluminium sidecar & single sided front suspension. 2854237993
Building a BMW K100 with aluminium sidecar & single sided front suspension. Au-log10
+1.......indeed.
Lovely work guys. I must compliment you on the shape and proportions of both the side car and the seat tail.
Building a BMW K100 with aluminium sidecar & single sided front suspension. Ir-log1188....May contain nuts!Building a BMW K100 with aluminium sidecar & single sided front suspension. Ir-log11
K75RTP - 1994
I'm no fan of sidecars, but this is absolutely wonderful  Very Happy
And so many pictures, a total big +
Building a BMW K100 with aluminium sidecar & single sided front suspension. Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
ausbrick
ausbrick
That is an amazing piece of work , pity its on the wrong side of the bike for Aus I'd love one but you can have your roads . cheers Ab
zonenfeile
zonenfeile
uff..  Shocked  Shocked  almost speechless
top ..  Building a BMW K100 with aluminium sidecar & single sided front suspension. 112350  Building a BMW K100 with aluminium sidecar & single sided front suspension. 112350
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
BIG D
BIG D
Cool
"OH MY GOD" I take my hat off to you, such work it was a pleasure to see this thread thanks for sharing wonderful job. Building a BMW K100 with aluminium sidecar & single sided front suspension. 112350
BIG D
GTJos
GTJos
BIG D wrote:Cool
BIG D
And yet another: +1 !!
My respect... :BW:
Jos
Building a BMW K100 with aluminium sidecar & single sided front suspension. Deutch10Ich bin enge Kirchröatsjer jong; adieë wa ?! Building a BMW K100 with aluminium sidecar & single sided front suspension. Deutch10
                                1992  K1100LT 6458188
                                1987 K100LT (RS-fairing) 0170844 + sidecar EML GT2001
                                1986 K100RS 0085647 + sidecar Velorex 562
                                1985  K100RT  0027026
Ooh Yeah a great post, thanks for the chance to read and see your and your dads sidecar story
mleikarnes
mleikarnes
Some more pictures of the latest progress in the build!
Making of the sidecar supension link, the spindle is out of an old Audi 80 rear spindle bearing.
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0725
The shock mount is cut out of a Suzuki GS500E frame we had lying around that wasn't usable for anything else...
https://lh6.googleusercontent.com/-OxydQ703BBM/U3HqOv1X2gI/AAAAAAABXtE/IvRdfPvv-I4/w913-h685-no/IMG_0729.JPG
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4230
Spindle mounting on the sidecar frame:
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0733
Mockup for the shock mount, the shock is to strong for this use (even though it's broken when on the GS500E...)
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0735
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0736
The mill we borrow didnt have the right size drill bit, so we opted for the easy way:
Building a BMW K100 with aluminium sidecar & single sided front suspension. 20140516_223828-MOTION
And then the clip-on from the GSXR-750 fitted nicely!
Building a BMW K100 with aluminium sidecar & single sided front suspension. 20140516_224128
Today dad milled down the upper triple clamp to make it a bit slimmer:
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4312
The mill did not cooperate at the last cut and made a groove in the clamp, but it will be nearly hidden...
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4313
Here we see the difference in thickness, the lower triple is the original size and the upper is milled down.
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4315
We're gonna have to use the lathe on the legs to shorten them a bit!
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4316
Clip-on's mounted!
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4318
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_4319
https://plus.google.com/u/0/photos?pid=6014129725015597170&oid=115648026825024221524
Leikarnes MC
mleikarnes
mleikarnes
Front steering linkage photos!
Two aluminium bars turned into "fork" legs
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0742
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0743
Linkage to counteracte the wheel travel upward and backwards. The links are made from the GS500E too, both the pipes seen are the bushings in the rear shock linkage for the GS500E
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0744
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0747
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0748
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0749
Building a BMW K100 with aluminium sidecar & single sided front suspension. 20140511_175902
Building a BMW K100 with aluminium sidecar & single sided front suspension. 20140511_175917
Here it is out on three wheels!
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0757
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0758
The rear wheel spacer is not done yet, waiting for the lathe at dads work to become free for use, someone is using it to take a test...
Building a BMW K100 with aluminium sidecar & single sided front suspension. IMG_0760
Leikarnes MC
GTJos
GTJos
Building a BMW K100 with aluminium sidecar & single sided front suspension. 112350 As always: top !
And: good to see some sun instead of ....  Blizzard    !! Enjoy...
Jos.
                                1985  K100RT  0027026
mleikarnes
mleikarnes
Some more pictures from yesterday!
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3826
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3835
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3838
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3845
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3839
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3842
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3846
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3848
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3849
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3861
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3860
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3862
Adjusting the angle of the bike and sidecar:
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3856
Out testing some!
Building a BMW K100 with aluminium sidecar & single sided front suspension. _MG_3859
Leikarnes MC
GTJos
GTJos
Very Happy "I love it when a plan comes together"...
Building a BMW K100 with aluminium sidecar & single sided front suspension. ATEAM%20Hannibal-thumb-200x247
 Building a BMW K100 with aluminium sidecar & single sided front suspension. 112350 Jos.
                                1985  K100RT  0027026
kartooo
kartooo
WOW !!
you got a kazillion hrs into that beautiful thing and have a big reason to be proud.
being built on a K bike it should last for a few generations
85 k100rt current
04 vulcan 1500 classic sold
07 bonneville black sold
05 fjr1300 sold
04 r1150rt sold
91 k100lt sold
r80rt sold
85 K100 sold
floyd
floyd
Fantastic vision and work! You guys must be proud as punch! Wonderful to spend such good time with your old man too.
Good to see another red frame Wink Really like the new tail section on the red frame bike - the way the frame comes up and looops around is very nice. Would be a great look for a street tracker style mod.
mleikarnes
mleikarnes
We've started fiddeling with the K again! My dad has made a new swingarm, the last one was too short to get the suspension geometry right. There was no room to move the lower spring mount around to get more suspension travel.
The old swingarm and pipes for the new one.
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_0957
New swingarm being mounting:
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1045
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1043
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1052
New and old swingarm, the new one looks more lean and is better made to accommodate better suspension
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1058
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1059
Ready for mounting of the hack!
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1061
Hack trial mounted!
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1086
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1089
Hack suspension:
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1116
Building a BMW K100 with aluminium sidecar & single sided front suspension. DSC_1118
Leikarnes MC
I just shorted my keyboard. Too much drooling!
Building a BMW K100 with aluminium sidecar & single sided front suspension. Drooli10
Amazing job, I am speachless.
CF
Building a BMW K100 with aluminium sidecar & single sided front suspension. Frog15Building a BMW K100 with aluminium sidecar & single sided front suspension. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
mleikarnes
mleikarnes
Crazy Frog wrote:I just shorted my keyboard. Too much drooling!
CF
Building a BMW K100 with aluminium sidecar & single sided front suspension. 44271
Just get some steel and get started!
Gotta build a bit different to stand out from the crowd of all the bought bikes and sidecars!
Leikarnes MC
GTJos
GTJos
CF
cheers  +1 !!
Great job, compliments, once again ! Too sad you live that far away; we should have been neighbours...
Keep on the good work and keep us drooling Very Happy
Jos
                                1985  K100RT  0027026
Wow!
K75RTP - 1994
Mossy1200
Mossy1200
Never seen anything like these sidecars on our roads.
