Advice please - main loom replacement Mon Dec 30, 2013 1:20 am
Mike101
Some of you may remember that i had a small fire on my k100LT a few weeks ago. I was hoping that is was just the wires from the ignition barrel to the loom connector that had gone but alas not.
I finally got around to stripping it down last saturday and found that the damge is from the ignition barrel right through the main loom and almost up to the fuse box.
So i need to replace the main loom.
I need help on the following points please.
1. Is the 4v loom the same as the 2v loom..mine is an 87 2v.
2. All advice and help welcome on home to do this. It seems like its just a unplug, replace and plug job but and i missing something?
3. What else might have been damaged?
4. Why didn't the fuse blow shutting off power from the battery?
Help please.
Mike
Help please.
Mike
K100LT 1987 Gold and not Beige
XT660Z Tenere
