1Back to top Go down   Ignition barrel Empty Ignition barrel Tue Dec 31, 2013 8:01 am
Mike101
Mike101
I'm replacing my main loom and ignition barrel loom after a short and fire.
I have the barrel off the bike but how do i remove the key lock part from the base and cables.
I dound a post on here about how to service it all but not how to split the barrel.
Any ideas please?
Mike
K100LT 1987 Gold and not Beige
XT660Z Tenere
2Back to top Go down   Ignition barrel Empty Re: Ignition barrel Tue Dec 31, 2013 9:34 am
There may be a small grub screw under a dot of paint, green I think and that should come out of the lock section
3Back to top Go down   Ignition barrel Empty Re: Ignition barrel Tue Dec 31, 2013 9:03 pm
the.postman
Or may be red paint. See Here
1984 srx 600
1986 cbr1000f/h
4Back to top Go down   Ignition barrel Empty Re: Ignition barrel Tue Dec 31, 2013 9:11 pm
A ignition switch looks a bit different on a 4V than a 2V, but red paint is used
on both...to secure the grub screw that holds the switch part to the barrel housing.
Here is a 2V switch, grub screw is to be seen in third Picture.
5Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 4:34 am
Mike101
Mike101
Inge K. wrote:A ignition switch looks a bit different on a 4V than a 2V, but red paint is used
Thanks..but I don't have any little screw anywhere on the black barrel,
I have a 2 valve 87 non ABS.
Mike
XT660Z Tenere
6Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 4:39 am
time to post up a pic mike ?  or several of around the circumference of the switch assembly ??? might help ??
7Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 5:06 am
There will be a small grub screw about 3mm diameter with a slot to get a small screwdriver in. It is located around the outside of the cylindrical alloy and locks the plastic switch into place. It usually has a small dab of paint over it so the dealers can see if anybody has tampered with it. The top of the screw will be about flush with the alloy.
8Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 6:43 am
Mike101
Mike101
charlie99 wrote:time to post up a pic mike ?  or several of around the circumference of the switch assembly ??? might help ??
Every time I try to post a pic on here it fails.
Mike
XT660Z Tenere
9Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 7:23 am
Ignition barrel Tennin11
10Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 12:37 pm
Mike101
Mike101
Got it apart now...thanks chaps.
Mike
XT660Z Tenere
11Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 12:39 pm
Ignition barrel 112350
12Back to top Go down   Ignition barrel Empty Re: Ignition barrel Wed Jan 01, 2014 10:55 pm
good result guys
 Ignition barrel 723598
13Back to top Go down   Ignition barrel Empty Re: Ignition barrel Thu Jan 02, 2014 5:42 am
Mike101
Mike101
The reason why i couldn't see it was that the hole was filled with black crap..so i could not see the red paint.  It didn't even look like a hole as it was so full.
The pic above solved it.
Cheers again....now i just need to sort out this loom.
Mike
XT660Z Tenere
