1Back to top Go down   Changing a headlight bulb Empty Changing a headlight bulb Mon Nov 18, 2013 8:59 am
Mike101
Mike101
Yesterday i tried to change my headlight bulb for somehting a little brighter and also to learn how they come out.  I have always found that they blow at night in the middle of nowhere so i thought it a good idea i learnt how to do it.
I can get to the bulb, get the plug off the back and peel back the rubber boot but how the hell does the bulb come out.
I can't see any springs, clips or anything to move or flick or lever to get the thing out.
Also what is a good buld to put back in.  I have the standard H4 and i want somehting a bit better...any ideas please.
Mike
K100LT 1987 Gold and not Beige
XT660Z Tenere
2Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Mon Nov 18, 2013 9:47 am
dutchie
dutchie
Hi Mike,
To replace the bulb:
1- Pull the connector off of the back of the bulb.
2- Pull off the rubber boot.
3- Remove the bulb.
Earlier K bikes have a retainer ring that needs to be turned about 20 degrees counterclockwise to remove the bulb:
Later K bikes have a clip that you push in and pinch.  Then it rotates back and to the left.
Dick
K75RT 1996 Changing a headlight bulb Klettern
K100RT 1986
3Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Mon Nov 18, 2013 10:39 am
Brad-Man
Brad-Man
Mike:
Unless you put in a Bi-Xenon HID conversion kit (not sure if legal where you live), if you put in a more powerful H4 bulb I would put in a relay kit to avoid overheating your switch and wiring.
For that matter, putting a relay kit in may brighten you up, so I'd start with that, and see if you even need a higher wattage bulb.
Just a suggestion...
4Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Mon Nov 18, 2013 11:17 am
mike d
1. Philips X-TremeVision
2. Ring Xenomax
3. GE Megalight Ultra +120
4. Osram Nightbreaker plus
All available in 55/60w H4, so no need to upgrade with relay switching (but you could do that as well!)
Mike
5Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Mon Nov 18, 2013 5:28 pm
Here's a pic of the retaining ring that dutchie mentioned, Mike 101
 Changing a headlight bulb Sam_0719
And +1 to the Philips X-TremeVision, mike d.Changing a headlight bulb 112350
6Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 5:57 am
Mike101
Mike101
sidecar paul wrote:Here's a pic of the retaining ring that dutchie mentioned, Mike 101
Thats the beastie i have...thanks.
I'll have another play this weekend.
Cheers all for the info. Again lots of good help on here.
Mike
XT660Z Tenere
7Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 6:58 am
Mike you will find them quite easy to get out if you have seven fingers with 4 universal knuckles in each finger.
If you don't meet those parrameters then have a ready supply of bandaids
8Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 7:11 am
Nowdays I take the window away, no matter manual or electric, gives me more space to change the bulb from above.
Also a good chance to replace the little bulb, I'm already there.
Once you found your own trick to replace, it's as easy as placing panniers  Cool
9Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 8:48 am
I agree with this one, it can make a big difference. I just got some ceramic bulb connectors and even that made a difference.
10Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 10:51 am
the.postman
RicK G wrote:Mike you will find them quite easy to get out if you have seven fingers with 4 universal knuckles in each finger.
The dexterity of a gynecologist helps,
Deff. "GYNECOLOGIST"..a person who can decorate his hallway from through the letter-box. Laughing
1984 srx 600
1986 cbr1000f/h
11Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 11:13 am
Mike101
Mike101
Wheeldigger wrote:Nowdays I take the window away, no matter manual or electric, gives me more space to change the bulb from above.
Oh don't get me started on the panniers.  I have no idea how they went back on but they haven't fallen off yet so all's well.
Also the seem to have been made impossible to open in the dark with cold fingers.
Mike
XT660Z Tenere
12Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 8:07 pm
AJ.Valente
AJ.Valente
Here, my problem is with an old bulb not putting out sufficient light, and so will try one of the newer 60/55 bulbs.* If the electrical wiring is underperforming and the new bulb doesn't help then I'll move up to an Eastern Beaver solution. But, don't mind me, I've got enough on my plate already for this winter and need to stay focused on the job(s) at hand.
*Recommended from other threads:
1. Philips X-TremeVision (highly rated on this forum)
2. Ring Xenomax
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
13Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 9:46 pm
If for no other reason, I'd do HL relays/beefed up wiring just to improve the switch longevity and get more voltage to the headlight.
I run high watt (130/90) cheapos from China (w/ 14 AWG wiring from relays) and they do amazingly well for $4 each.
A few of the K bikes I've purchased have had 60/55 Osram H4s which are noticeably better at night.
The factory wiring is wimpy and halogen technology from 1985 is a bit dated these days.  Kind of like walking in front of a horse with a candle.
14Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Nov 19, 2013 10:04 pm
They arent as bad as the old Lucas (prince of darkness) lights where you had to turn then on and off a few times to be able to tell if they were actually working.
15Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Wed Dec 11, 2013 1:22 pm
frogy
frogy
+1 on Eastern Beaver Relays. It is heavy duty-plug and play.
When my bulb burns out I might try one of them new fangled LED bulbs. Shocked
16Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Wed Dec 11, 2013 2:04 pm
I bit the bullet and popped a very bright and white PIAA 'extreme white' globe into my RT. It and the 11.9" LED strip below the headlight brighten my passage through the darkness quite well. In comparo to the wimpy and yellowy output of the Osram halogen I can now see and am now seen. Doesn't mean the buggers don't still cut me off!
Why PIAA when they cost so much and are often so fragile? There's bennies to working in the biz. I'm not paying retail.
~Mac McCleary
17Back to top Go down   Changing a headlight bulb Empty Re: Changing a headlight bulb Tue Dec 31, 2013 3:14 am
Sunnyk75
Sunnyk75
+1 on new relay kit. I ended up beefing up with an Eastern Beaver relay kit as well but it was because my headlight switch suffered the plastic meltdown and I could not go between low beam to high beam without the light cutting out. Unfortunately, when one is riding out on the open road and one or two seconds of total blackness before the high beam engages makes for some real adventurous riding.
Running the new relay kit, replacing a new H4 bulb, after figuring out how to remove the old bulb as described in the above reply on removal of the metal retaining ring, was hugely satisfying when I noticed the circuit really pumped up the light intensity to a noticeable difference even on low beam.
Good luck with the replacement.
Sunny
