Number of posts : 7886
For what its worth when I had mine apart I found that it went back together really easy, then checked it and found it was the wrong way. To get it back together the correct way is little more tricky. It felt like it wanted to go back together the wrong way.
If in doubt put some marks on it before you open it. Then reassemble it the opposite way and pop it back in. If that solves it then you are sorted. But a common thing is to mark it before disassembling, then go to town cleaning the outside and when it comes to reassembly the marks are cleaned off. So when you know its right do use a permanent means of marking like some scrapes of a sharp screwdriver on the casing where the end and casing meet. Or a dab of paint.
1971 Yamaha 125 YAS-1
