1 K100 gearbox Tue Jan 07, 2014 9:16 pm
Rockman
I have a spare K100 gearbox. No idea of its history. Any suggestions as to how I check if its any good. Its loose, not on a bike.
RicK G wrote:There are two shafts about 12mm dia and are the ones the selector forks slide on try to keep them coming away with the front. you will need to lift the lid about 1/2in then you can see the shafts and get a blade at them to prevent them moving with the lid. The Haynes explains the gearbox fairly well and if you haven't got one get it here https://www.dropbox.com/s/1duzdms9c23wjpk/K100%20Workshop%20Manual.pdf
RicK G wrote:More torque can be transmitted through a 20 spline than a 16 of the same diameter but to make it work you need a uni joint both end not one end.
The Kawasaki z1300 or KZ as you know them had much the same problem but at least you were told to lube them.
Similar topics
