1Back to top Go down   Alternator Compatibility  Empty Alternator Compatibility Fri Feb 14, 2014 10:34 am
k75RT Keith
k75RT Keith
Got offered a 50 amp alternator from a R1150RT.  The part number from BMW and the plate match and it looks like the bolt pattern is the same. if I replace the pulley with a cup should it fit?  Anyone know of this observation is correct?
2Back to top Go down   Alternator Compatibility  Empty Re: Alternator Compatibility Fri Feb 14, 2014 11:01 am
not sure about the r series
but please, make sure if you do it ...measure , measure , measure ..before you tighten it up
there are a couple of different cups that look similar , but project further onto the drive coupling
maybe mike p knows ?
good luck !
3Back to top Go down   Alternator Compatibility  Empty Re: Alternator Compatibility Fri Feb 14, 2014 11:02 am
The 50A alternator itself is similar on both models......and a lot of others.
4Back to top Go down   Alternator Compatibility  Empty Re: Alternator Compatibility Fri Feb 14, 2014 1:08 pm
klamityboy
klamityboy
charlie99 wrote:not sure about the r series
good luck !
Duck would also be a great resource on this as he breaks down K's and sells parts. Also, his Frankenbrick is a composite of a number of different bikes.
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
