1Back to top Go down   Lucas 80w85w gear oil Empty Lucas 80w85w gear oil Thu Apr 03, 2014 4:50 pm
martyman
martyman
I like Lucas products and I grabbed a bottle of this...is it ok to use for my transmission?
http://www.lucasoil.com/images/products/SAE_80W_85WTransmissionOilSynthetic_lrg.gif
2Back to top Go down   Lucas 80w85w gear oil Empty Re: Lucas 80w85w gear oil Thu Apr 03, 2014 8:17 pm
Don't see why not
3Back to top Go down   Lucas 80w85w gear oil Empty Re: Lucas 80w85w gear oil Fri Apr 04, 2014 10:39 am
martyman wrote:I like Lucas products and I grabbed a bottle of this...is it ok to use for my transmission?
As long as it also says it's GL5 and Hypoid somewhere on the label, then go for it. The 'weight' range or viscosity is adequate.
4Back to top Go down   Lucas 80w85w gear oil Empty Re: Lucas 80w85w gear oil Fri Apr 04, 2014 12:35 pm
martyman
martyman
I called Lucas and they said that it is GL5 and Hypoid.  The fluid that I dumped out of it looked and smelled like motor oil and was thick, I wondering if the previous owner put in motor oil?  I did put the Lucas in and went for a ride and the shifting was very smooth could shift with running shoes on (just for a test ride around my neighbourhood).  The person I spoke to at Lucas said that it should be fine so I will try it for a while.
