1Back to top Go down   Rear brake question 85 K100RS Empty Rear brake question 85 K100RS Mon Apr 20, 2015 11:07 pm
diversity48
diversity48
After bleeding the front brakes succesfully, I tried bleeding the rear. Seems that I have a bad Master cylinder, here is what it does: Removed most of the fluid from the reservoir, filled it with fresh fluid, and proceeded to drain the caliper using a "Mity-Vac" which I have used on other bikes and on the front calipers with complete success. Only could get a few drops into the canister of the mity-vac at first, and after pumping it several times, ended up with only a very small amount of fluid there...possibly 1/2" or so in the bottom of the canister. Tried bleeding the old fashioned way...pumping the pedal, and after MANY pumps, probably 100-150 or so, finally got the rear brake to function, but just barely. Now I have very little rear brake power. After reading related posts on the subject, I'm thinking that it may be the master cylinder. With these symptoms, what would your opinion be? I have not taken the caliper off, but I'm thinking that even with leaky seals, the caliper should at least be kicking out some fluid from my efforts. Just need some educated guesses here...what do you think?
2Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Mon Apr 20, 2015 11:35 pm
KafeRacer
KafeRacer
I have a rear master if you need one $50 usd delivered.
Cheers.
Dave Evans
'Kafe Racer'
kaferacer.wordpress.com
1990 K75RT
1985 K100 Kafe Racer
http://kaferacer.wordpress.com
3Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Mon Apr 20, 2015 11:42 pm
Are you seeing the fluid level in the reservoir going down?  If not, there may be a blockage in the supply from the reservoir to the master cylinder.
Is there fluid leaking out under the boot where the pedal pushes on the master cylinder piston.  If yes, the piston seals are bad and you're pissing the fluid out on the floor.
Can you disconnect the brake line at the caliper and get fluid when the master cylinder is pumped?  If yes, you may have a blocked bleeder.
4Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 21, 2015 12:31 am
diversity48
diversity48
No leaking beneath the bike ... it would be obvious if it was leaking there. I pumped the hell out of the pedal and the reservoir on the bike remained at or very near the same level. Normally, with the bleeder system I have, it supplies enough "suck" to deplete the reservoir rather quickly. Not so in this case.  The reason I'm suspicious of the master cylinder is that no, or at least very little fluid seems to be getting back to the caliper. It went from "no rear brake" to "very little" rear brake.
5Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 21, 2015 12:34 am
diversity48
diversity48
Oops...NO, I haven't tried disconnecting the hose at the caliper...good thought though...at least worth a try. Also could be the blocked bleeder, but if it were, wouldn't the brakes at least function?
6Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 21, 2015 1:50 am
brickrider
brickrider
I replaced the line on the rear brake last year thinking a stainless steel one would firm up the pedal.  No joy.
My bike is a 1985 K100RS too.  It has only about 40K on the clock, but that spongy rear brake has me wondering if the m/c isn't K-putt.  Does BMW sell rebuild kits for the master cylinder of the rear brake?
7Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 21, 2015 6:04 am
brickrider wrote:I replaced the line on the rear brake last year thinking a stainless steel one would firm up the pedal.  No joy.
I had same issue with my 92 K100LT rear brake. We got a rebuild kit for the master cylinder and it did the business. also did the 84 K100RT last April. Rebuild kits used in both cases but the RT needed a replacement reservoir [cheap] and also needed the pistons and caliper seals sorted. Pistons were sticky giving no real braking pressure.
8Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Wed Apr 22, 2015 1:01 pm
I suspect a rebuild will be necessary. From your description I'm pretty sure that the feed hole in the m/c is blocked, so no (or very little) fluid is getting into the brake line. A blocked return hole will give similar symptoms.
What doesn't help is that BMW have a rubber block between the brake pedal and the m/c piston. This softens up the feel still further. My guess is they designed it in there to make locking up the rear wheel less of a problem. I threw mine away and replaced it with a length of stainless steel shaped to mimic the plate on the end of the rubber block. Much more feel and feedback.
While you're down there, pull the rear brake caliper off, remove the pads and scrub the guaranteed pile of crap out from the middle of the caliper. That will definately help with the braking. The dirt that gets in there can prevent the pads from moving smoothly; if it's bad enough I've seen it stopping the pads moving at all.
9Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 11:08 am
diversity48
diversity48
Guess I never really thought the caliper would be the suspect, but at least a :going through" on it would eliminate that. Gonna try that (hopefully today) first and see how far I get. Next would be either a new master or rebuilding the old one. Found a new one at bmw2valve.com for $169 that may be the ticket although more than I wanted to spend :-(...starting with the caliper first tho without pulling the trigger on the new m/c.
10Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 2:54 pm
brickrider
brickrider
Personally, I'm inclined to go to MotoBins for a rebuild kit.  My bike seems to have been pretty well maintained by the previous owner(s) so I doubt the bore of the master cylinder is so pitted that a rebuild won't restore proper action.
And what's this about a rubber bit to soften the feel of the pedal?!  I must have a closer look down there.  That sure sounds like a daft idea to me, but then what do I know as compared to the BMW engineers?  Shocked
11Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 5:03 pm
Rear brake question 85 K100RS Ssl10911
That black bit is the rubber part, Brickie......I tried replacing it with a solid stainless part, but I didn't like it (no 'feel' at all) so I added a 2.5 mm thick ring on the rubber to reduce the amount of squish. Works for me.
Rear brake question 85 K100RS Ssl10912
12Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 5:54 pm
One thing to bear in mind when overhauling Brembo master cylinders (and someone here is really going to argue with me over this!); two overhauls and that's your lot. Shocked
Okay, so that's the factory statement  Very Happy
Experience shows something different but there is a limit. When you've got the piston out, hold the body up to the light and check the insides very carefully. If it's nice and shiney and has wide silver streaks in there, introduce it to the bin. The surface anodising has worn off and the chances are even a new seal will either not work or will not work for very long.
Yes, I have fallen foul of this. The symptoms are an overhauled system that will bleed well but will not hold pressure. It happened to me about fifteen years ago and I ended up having a very nice chat with a Brembo rep who gave me the 'two overhauls' information. Unfortunately I had to buy my own replacement master cylinder Sad
13Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 6:24 pm
brickrider
brickrider
I've heard it said by some of the wise men in the airhead community that even one rebuild on those front brake master cylinders is a waste of time and money. I understood the reason was pitting of the bore; never thought of the possibility of them being anodized or otherwise finished in any way.
I like the idea of a ring to limit the expansion of the rubber bit in the m/c.  I can see that having a lathe in the shed is better than a very good thing Smile  ... but then I'd have to learn how to use it Razz
Last edited by brickrider on Thu Apr 23, 2015 6:25 pm; edited 1 time in total (Reason for editing : grammar)
14Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 6:24 pm
I have to agree with this.
Not a surprise I hope.
15Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Thu Apr 23, 2015 6:44 pm
brickrider wrote:I've heard it said by some of the wise men in the airhead community that even one rebuild on those front brake master cylinders is a waste of time and money. I understood the reason was pitting of the bore; never thought of the possibility of them being anodized or otherwise finished in any way.
I have to utterly disagree with that sentiment. AFAIK the only thing that could cause pitting would be poor maintenance allowing sh!t to get in and/or not changing the fluid often enough. In almost thirty years of overhauling Brembo master cylinders on Guzzis, Laverdas and BMWs I have seen two that were visually worn beyond use (including the one that caught me out) but never one that was pitted. As I'm only a home mechanic and not a bike pro, I'd guess I've done perhaps 30-40 master cylinders front and rear and maybe 60-80 calipers of the P08/F08 type.
16Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 28, 2015 11:05 am
SteveK1
SteveK1
OK, so from what you are saying I cannot overhaul my front master-cylinder?  I have a 16 valve K1 and I think it has an all-aluminum 20 mm MC.  I rebuilt it previously with new piston and seals, honed the bore.  Several months later it seized up the front calipers and pitched me off.  Thinking it may have been not cleaned adequately I have re-honned it and cleaned it in a sonication bath.  I was about to reassemble it.  Are you saying I would be unwise to try using this and would do better to source a new MC body? Could one re-anodize the bore?
Last edited by SteveK1 on Tue Apr 28, 2015 11:11 am; edited 1 time in total (Reason for editing : spelling)
BMW K1 1990
BMW R60 /5 1973
BMW R100R 1992
Honda CB360T 1975
17Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 28, 2015 2:46 pm
Personally I'd be looking for a replacement master cylinder.
18Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 28, 2015 3:34 pm
SteveK1
SteveK1
Dai wrote:Personally I'd be looking for a replacement master cylinder.
Personally? Why? Because of the all aluminum versus steel cylinder? More information please.
Reading in the thread, it looked to me like the MC I have should be repairable.
https://www.k100-forum.com/t1301-brake-seizure
BMW K1 1990
BMW R60 /5 1973
BMW R100R 1992
Honda CB360T 1975
19Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Tue Apr 28, 2015 6:39 pm
Time to give my one cent of advise and experience..
Have you tried to play with the adjustor screw on the MC (This is the link between the pedal and the MC- #12 on the first picture- and screw #3 on the second one)
If the travel of the piston is limited, the piston will never return to the position where the filling hole is cleared to let more brake fluid re-enter the MC.
It's worth playing with the adjustments before replacing the unit.
Rear brake question 85 K100RS Mc10
Rear brake question 85 K100RS Mc210
Rear brake question 85 K100RS Frog15Rear brake question 85 K100RS Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
20Back to top Go down   Rear brake question 85 K100RS Empty Re: Rear brake question 85 K100RS Wed Apr 29, 2015 1:22 pm
As you say, it's been honed twice, so I wouldn't trust a new seal kit to make a good seal in there. Perhaps I'm being too cautious but experience is a hard taskmaster and I'd rather be absolutely sure of my brakes. You could try an overhaul kit and find it will work perfectly; I'd also check the two holes very carefully when you have it apart.
