Finnigan
Finnigan
Would like to remove the ABS gear/ring from the rear rotor if possible.  Has anyone done this?
1990 k100LT
two66mhz
two66mhz
You will need a Rear Master that is for non-abs. I attempted to bypass my pump and the master cylinder would not bleed back.
3Back to top Go down   K100LT: Does the ABS ring come off the rear rotor? Empty abs ring removal Mon Jun 23, 2014 5:46 pm
audibob
audibob
Hi Finnigan,
I removed both of mine recently after fitting new ebc discs.
I heated the disc in my oven for half an hour, then used an angled tyre  lever between the domed disc fixings on the original disc and the underside of the abs ring, working around the rim.
Once it moved, it came off fairly easily.
Hope this helps.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
Finnigan
Finnigan
Thanks Bob, I'll try that
1990 k100LT
I apply heat from a butane blow torch and it comes off very easily with a couple of levers to help.  Putting it back just heat the ring and it usually just falls on and then pull the 3 small bolts down to make sure its seated square.
