1 Smoke on start. Random? Thu Jun 05, 2014 8:55 am
bignews1and2
8 out of 10 times my 1985 K100 RT will smoke on start even if I lean it to the right first and then park on the center stand. It smokes for 10 to 30 seconds and then stops. I had previously searched the forum for "smoke" and read all the articles. Since it still happened on the center stand and I drained the oil and put exactly 3.6 quarts back in, I started to think it was an O-ring. But now due to the randomness i think it has to do more with the design flaw later fixed. Do you have to leave the bike running while leaning to the right, shut off and hold for a bit more?
Also, whenever I use the side stand after a ride when some time has passed I can check the oil sight glass and it is white.
However when I use the center stand it always seems to stay black. Is the proper reading from this gauge supposed to be white on top and black on the bottom, red dot indicating the high point of oil?
Thanks!
Thanks!
1985 K100RT 0052326
