1 Engine Noises Sun Aug 03, 2014 1:45 am
I have had my 1994 K75RT for a little over three months now and have almost 5,000 miles on her, mostly interstate at 65mph+ as I commute 110 miles per day to and from work. Bike was well cared for by previous owners and does not look it's age.
Bike had lots of rattles and engine noises which I have been hunting down. Found bad bearings in the alternator, replaced the alternator and rubbers, but a tapping/clanking noise, while reduced, is still there, coming from somewhere between the alternator and the starter.
The engine ran a bit rough when I got it, but running Seafoam in the gas has smoothed things out a lot. Also did an idle vacuum balance on the throttle bodies which has helped. Engine idles well, but a little fast(1050rpm) and has nice throttle response.
Had noise coming from the front of the engine that I thought might be timing chain slap. Bike has 59,000 miles so I decided to replace the chain and the tensioner/guides. All of the old parts still looked like new when I replaced them. As I expected from the old parts condition, there was no significant impact from the change.
The problem I am after now is that when riding, I get a lot of clatter from around the intake valve on cylinder #1 at idle that goes away at 2000rpm. When I changed the timing chain I checked valve clearances and all were at the bottom of the spec, .006-.007" on intakes and .010-.011" on the exhaust. Low, but in spec.
The engine runs like a sewing machine from 2000 to about 5000rpm, but above that begins to clatter again, the exhaust note get a lot louder and changes to more of a moaning snarl, and the engine develops a mild vibration that is barely perceptible in the grips. While it is making all this commotion there is no discernible loss of power or throttle response.
What should I be looking for, or is this normal for this bike? I think she shouldn't be behaving like this. The clatter at idle and low rpms is annoying while the clatter at high speed makes it hard to relax and enjoy the ride.
