1Back to top Go down   K1100 throttle position switch Empty K1100 throttle position switch Fri Aug 08, 2014 10:57 am
JGT
JGT
Had a surf around the forum but cannot find an answer to my question. Can the TPS be deactivated in the Motronic system or does it always have to be in circuit? I get the feeling it must always be in circuit to make the engine run. Does make the on/off throttle position and riding a bit jerky.  John
2Back to top Go down   K1100 throttle position switch Empty Re: K1100 throttle position switch Fri Aug 08, 2014 11:27 am
K11's don't have a throttle position switch, but a throttle position sensor.
4V's With Motronic don't have a airflow meter, and using the throttle position
sensor to calculate the amount of air used.
So, yes...you need it in place and functional on a 4V.
3Back to top Go down   K1100 throttle position switch Empty Re: K1100 throttle position switch Fri Aug 08, 2014 12:49 pm
JGT
JGT
Hi Thanks for reply, Will have to set it up using info from forum as it runs sooty exhaust at low speed and plugs are black. Out of interest, as it controls air flow, how sensitive is its setting?  John
4Back to top Go down   K1100 throttle position switch Empty Re: K1100 throttle position switch Fri Aug 08, 2014 1:40 pm
As one of the inputs to the Motronic for calculating the amount of fuel to be injected,
it have to be as correct as possible = better end result.
If it don't help after an adjusting.......also have a look at the other sensors,
water temp, air temp, O2 sensor, Co pot if non cat.
I think you find some info over at the K11OG forum.
5Back to top Go down   K1100 throttle position switch Empty Re: K1100 throttle position switch Fri Aug 08, 2014 3:07 pm
JGT
JGT
Thanks Inge K. Another interesting forum to investigate. John
