Number of posts : 11679
have a look for the "eastern beaver" headlight relay kits
buy all accounts a good solution for all those that are unsure ...or just want a good solution premade
personally I have mounted a few setups off a bracket that I made off the horn bracket on the left hand side of the fairing internals
like the eastern beaver kit ..I have used the current headlight (h4 ) connector as a socket for 3 spade type plugs to then go off to the relays as switching signal
power from the input connection to the starter relay ..via a fuse before it connects to the relays maintains some form of short circuit protection
I have done a couple now .....one of them had the relays in the fuse box all neat and compact
try the search feature "headlight relays "
you will find an immense amount of posts on this subject for your research
good luck and a very suggested modification
