1Back to top Go down   undefined oil leak at final drive Empty undefined oil leak at final drive Sat Mar 20, 2010 7:27 pm
philjw2
philjw2
Hi there,
I've got a 1986 K100 RT which has just 20,000 miles on the clock. It covered about 13,000 miles in its first 3 years, then around 3,000 in the next 20 years. I bought it in July and have put over 4000 miles on the clock, though most of the time I've had it, it has been stored inactive in a garage. It has recently developed an oil leak, the source of which is not clear. The oil is at the top of the shaft drive (next to where the speedometer impulse transmitter is) down to the final drive drain plug. It only leaks when driven and is depositing oil on the rear tyre and rear brake disc. I've just had the bike serviced (oils changed and valve clearances done) and the final drive drain plug was replaced and fitted with a new seal, however oil is still leaking - though not from the drain or filler plugs (as far as I can tell anyway). The shaft itself does not seem to be weeping oil. Is it possible that oil is leaking out of the rear shock? The rear shock is the original one. I can't think of alternative source for the oil.
Philip
how soon does it leak when it is cleaned, could you really thoroughly degrease with strong detergent so the paint surface looks a bit chalky, go for a ride and see where it is darkening with oil from?
phil_mars
Hi Philip,
Might be worth removing the speedo transmitter and make sure the o-ring is in good condition as it is doubtful it could come from anywhere else and double check the oil level in the final drive as it is only meant to up to the base of the bottom thread of the filling plug.
Phil
Ned
Ned
1. shock oil... there is not that much oil in the shock and they only tend to weep, from experience.
2. can you put some on a clean finger and smell it. Diff oils have a nasty distinct smell.
3. 4 holes in a diff:
a. vent hole (top)
b. speedo sensor
c. fill hole
d. drain
vent and speedo may be a problem. These are places I would check first.
I suspect o rings and overfill. Is it possible that the diff was filled through the vent hole?
The differential can also leak at the shaft seal on the wheel side.
undefined oil leak at final drive Frog15undefined oil leak at final drive Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   undefined oil leak at final drive Empty Re: undefined oil leak at final drive Sun Mar 21, 2010 12:50 pm
philjw2
philjw2
Thanks for all the responses.
I cleaned the area and rode the bike for 2 minutes before checking the oil leak site. It does seem to be leaking from the shock, the foam buffer (or what remains of it after 24 years) at the bottom of the shock is soaked in oil and running my finger around the plastic seal (where the piston goes in) showed that oil was weeping out. Estimating the amount of oil that has leaked out is difficlut but I'd say at least 40 ml has been lost. Not sure how much oil is actually inside a shock absorber, but the leak does correlate with a loss of performance. I carried a 15 Kg load yesterday on the back of the bike with the shock set on the middle setting - I got a whack with every small bump in the road! Even today with no load the shock was not absorbing the bumps.
Having just spent £300 pounds on a service I'm inclined to change the shock myself. It looks an easy job. Any advice on a brand of shock and the complexity of the swap welcome.
Many thanks for the advice received.
Regards Philip
Beachcomber had posted a sweet deal from realmengineering.
Check RAM Suspension by clicking here
If you tell them that you belong to this forum, they will give you an extra 10% discount.
Changing the shock is very simple and should be done in less than one hour.
8Back to top Go down   undefined oil leak at final drive Empty Changing the Monoshock Tue Apr 06, 2010 9:50 am
philjw2
philjw2
I fitted a Hagon shock in the end (nitro I think). On the expensive side (just shy of £300 including delivery) but it can be rebuilt and has a huge number of settings. Ordered by phone late Tuesday afternoon and recieved by Thursday lunch time. It was very easy to fit. I needed to use an alignment tool (narrow cone shaped tool) to line up the top eye of the shock with the twin holes in the frame and couldn't have got the bottom eye on the bottom bolt without the help of a mate pulling the rear of the bike up.
Philip
Last edited by philjw2 on Tue Apr 06, 2010 10:07 am; edited 1 time in total (Reason for editing : spelling mistake)
Ajays
Ajays
If you overfill you will blow oil out and wet your rear tyre.
At a low mileage I would have thought you have overfilled it.
Always ensure you have the level in the sight glass correct.
Do this before anything else.
Ajays
If it is the shocker and you have it on the centre stand be sure to support the wheel when removing the shock. Important to do this.
Last edited by Ajays on Tue Apr 06, 2010 1:59 pm; edited 1 time in total (Reason for editing : Further info;)
10Back to top Go down   undefined oil leak at final drive Empty Re: undefined oil leak at final drive Wed Apr 07, 2010 3:47 am
green cat
green cat
You can also ask there
http://brooksuspension.co.uk/shop/bmw-emc-c-27_43_106_628_641.html?osCsid=372116798b85c5f8ac96f46890527b25
the EMC shocks are totally rebuildable. Here in France it takes 3 days and costs 180€... But the shocks are much more expensive here... don't know why but for you english people it's a bargain!!
[img]undefined oil leak at final drive 3cc2228804714fdc8e93fe1f84a93706[/img][img]undefined oil leak at final drive K1100l10
