1 Leads & Plugs K1100 Sat Nov 08, 2014 4:23 am
mike d
Hi All,
There has been previous discussion about the K100 OEM resistive HT leads, and associated non resistor fitted plugs and how resistor fitted plugs should be used with replacement HT leads/caps which do not have the built in resistance.
So.......................
Does anyone know then why the K1100 (which has a 6K ohm lead/cap) uses a Bosch XR7LDC, where the 'R' denotes the interference suppression resistor.
In a similar fashion, on the Motorworks site the XR5DC is called up for the K100RS 16v and K1.
Mike
Mike
