1Back to top Go down   Front brake jamming Empty Front brake jamming Wed Dec 10, 2014 12:13 am
Wheel Rut
Wheel Rut
I have not logged on here for a while because I travel away a lot for work.  Usually I go away for a month, and therein lies my problem.  My bike stands idle for a whole month at a time.
The last time I rode it felt like the front brakes were dragging, i.e. the callipers jamming on.  When I checked the front brakes, the left disc was warm, while the right disc was rather hot.
I'm not sure what the problem is, but I'm thinking that the right calliper is jamming, not seized.  Because it can be released, it just tends to drag while riding.
Do you think the problem is in the callipers or somewhere else?  Can these be repaired?  Any suggestions welcome.
(K100RS 16 valve with twin piston brembo's no ABS).
1992 K100RS 16 valve, colour red
2Back to top Go down   Front brake jamming Empty Re: Front brake jamming Wed Dec 10, 2014 1:37 am
JR_K100RS
JR_K100RS
G'day Wheel ,
                    same thing happened to me on mine , it's no biggy , I just got a caliper seal kit for each side , problem gone
John R
3Back to top Go down   Front brake jamming Empty Re: Front brake jamming Wed Dec 10, 2014 2:14 am
Quite often they just need cleaning, not even a seal kit.
The bore gets a build up of crud and the piston will stick a bit and not return fully. Be gentle with the pistons they are hard anodized aluminium and damage easily. Probably pay to strip the whole lot including the master cylinder as it will have a build up in it as well and that can cause the piston to stick in the bottom of the bore and will cause you all sorts of grief when bleeding time comes.
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
