1 Chair brakes. To have or not to have? 30/03/15, 08:02 am
touchwoodsden
I have been posting various things on here about my ongoing K100/Hedingham single seat chair.
I enquired from Hedingham about the possibility of fitting a brake to the chair because mine is a very early one which is unbraked.
Evidently the very very early ones had no facilities for brakes at all. The later early ones had tapped holes in the hub for a disc. Mine has no such holes.
I can see no problem in making suitable bracketry to attach a master cylinder and pedal to the chair frame.
I can also see little problem in making a floating plate to hold the caliper and bush in exactly the same way as happens on the Wasp front forks. It would need a torque arm with rod end bearings attached to a bracket on the chassis but that wouldn’t be a problem.
I’m wondering what the best way of attaching a disc to the hub would be bearing in mind that the hub has no spigot to locate the disc centre. It would also need a disc with a relatively small centre hole because the hub itself is not huge.
I know it’s relatively difficult for people just stabbing in the dark but any suggestions and/or photos would be extremely well received.
Whilst the reply from Hedingham was extremely helpful, the cost is going to be prohibitive at about 700 quid.
I don’t particularly want the brakes linked to the bike as I prefer the chair be braked separately.
On the other hand, should I really worry about a chair brake at all?
J
J
