1Back to top Go down   Hall effect sensors - cable length Empty Hall effect sensors - cable length Mon May 25, 2015 10:33 am
I'm currently building a new wiring loom for LFB and will be re-using the shielded HF sensor cable. However, the damn thing is a good five feet long - does it need to be this length for timing and signal propagation purposes or can I give it a good pruning?
2Back to top Go down   Hall effect sensors - cable length Empty Re: Hall effect sensors - cable length Tue May 26, 2015 12:27 pm
In the absence of any other information, I pruned it. Severely.
as long as the shielding is still in place ....shouldn't be an issue dai
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OHall effect sensors - cable length Au-log10
Thanks Charlie. The length of it made me wonder if the ignition circuit allowed for the amount of time it took for the signal to propagate from the sensor to the igniter.
As it is, I checked a second (discarded) loom and came to the conclusion that it was more likely that length for production purposes. It goes down the right side of the loom, along the crosstube in front of the relay box and then back up the left side of the loom to the ICU. The long way round.... very long way round.
5Back to top Go down   Hall effect sensors - cable length Empty Re: Hall effect sensors - cable length Tue May 26, 2015 11:13 pm
Doesn't sound standard to me. I've recently been researching HESensors and I've seen that sensors for industrial applications can have varying lengths of shielded cable up to 10m so that signals can be routed to monitoring equipment. I don't think the length will affect the signal at all.
  Hall effect sensors - cable length Austra12    Fuel:  95 Octane
6Back to top Go down   Hall effect sensors - cable length Empty Re: Hall effect sensors - cable length Tue May 26, 2015 11:31 pm
These things don't work at high enough frequencies for conductor length to be a consideration. it needs to be in the giga hertz range before conductor length becomes at all important
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
7Back to top Go down   Hall effect sensors - cable length Empty Re: Hall effect sensors - cable length Wed May 27, 2015 12:25 pm
Thanks guys - the info is definately appreciated.
