1 85 K100 injectors Wed Aug 01, 2012 2:37 pm
tdkclydes
Hello , I am trying to check the fuel injectors on a 85 K100 which has sat for 10+ yrs . I have tried to clean the injectors . The injector are off of the rail and I have pressurized the injector with air and cleaning solvent . When I press the starter there is no spray coming from the nozzle . If I connect a 12v tester to the electical connection I get current when I press the starter . I do not hear the injectors make any noise . Could the injector not be opening because of build up or does this sound more like a electrical issue ?
Thanks for any help .
