Topics [0]
pannier repairby brickrider2crack repair in plastic | 6 | 980 | Sat Aug 28, 2021 2:29 pm by brickrider2 |
89 K100RSby gsmithRestoration | 9 | 1195 | Wed Jul 28, 2021 2:58 am by Bonzo |
Warped discs from corrosionby Snod Blatter | 4 | 877 | Mon Jul 26, 2021 8:37 pm by MartinW |
37/11 final driveby arbalestK bike? | 2 | 692 | Sat Jul 24, 2021 9:19 pm by K75cster |
Y spoke wheelsby arbalest18"? | 4 | 1116 | Sat Jul 24, 2021 9:01 pm by Rick G |
Another K100RS Mirror Clip Questionby Bondoggle | 10 | 2286 | Fri Jul 23, 2021 2:19 am by tinyspuds |
ABS removal.by MartinWABS Removal. | 13 | 2906 | Thu Jul 22, 2021 5:35 am by poddy |
Repaintingby Bruce PettersonRepainting of the frame of a tired K75 S - showing some love ? | 5 | 842 | Tue Jul 20, 2021 4:00 am by Mick67 |
Vibration Damping Bellypan Bolts - Are they necessaryby KentM | 5 | 789 | Wed Jul 14, 2021 1:13 pm by RS Rider |
The Disappearing K1100LT tiresby brickrider2Front to Rear? | 24 | 1135 | Tue Jul 13, 2021 4:41 pm by jbt |
Seat replacement from RS to LTby ZiscoI need to understand which pieces I need | 16 | 1193 | Fri Jul 09, 2021 1:00 pm by Laitch |
driveshaft/final drive spline changeby arbalestK100 | 2 | 872 | Thu Jul 08, 2021 1:28 pm by arbalest |
"Wiggle" on sweeping turns - Bug or Feature?by KentMLooking for input on behavior I've noticed when entering/exiting freeways, or throttling through sweeping turns. | 14 | 1351 | Wed Jul 07, 2021 6:29 pm by KentM |
Wheel sizes and their dynamicsby floyd | 36 | 3697 | Fri Jul 02, 2021 5:37 pm by jbt |
General maintenance Torque settingsby tinyspuds | 4 | 865 | Wed Jun 30, 2021 10:14 pm by tinyspuds |
Paint resistance to Fuelby jjefferies | 4 | 714 | Mon Jun 28, 2021 3:20 pm by Point-Seven-five |
Heidenau K60by MMWW | 12 | 4623 | Mon Jun 21, 2021 5:15 am by Gaz |
ABS brake hosesby magicflemABS brake hoses 1990 K100 LT | 6 | 1010 | Fri Jun 18, 2021 11:25 pm by TacKler |
The Fix Up Continuesby yamaguzzi | 1 | 681 | Tue Jun 15, 2021 12:15 pm by Shep |
Pannier Capacity Comparison.by MartinW | 5 | 837 | Sun Jun 06, 2021 10:44 pm by MartinW |
1984 K100RS Styleby rodmcmLocation of decals | 20 | 1275 | Tue Jun 01, 2021 3:11 am by Bonzo |
Brake rotor configuration puzzleby tinyspuds | 8 | 1165 | Wed May 26, 2021 4:49 pm by 92KK 84WW Olaf |
Rear brake caliper pistonsby @kustom_moto | 13 | 1480 | Mon May 24, 2021 6:20 am by tinyspuds |
Rear shock height problemsby 87m6chris | 22 | 7864 | Sun May 23, 2021 7:22 pm by 92KK 84WW Olaf |
Help me out with brake line banjo torque settings?by Bonzo | 4 | 830 | Sun May 23, 2021 8:08 am by tinyspuds |
leaky front master cylinder and dowty washersby tinyspuds | 2 | 739 | Sat May 22, 2021 3:44 pm by tinyspuds |
K75 Radiator Cowling/Shroud/Radiator_Trim_Panel Repairby jjefferiesSolutions to broken tabs on Radiator Cowling | 5 | 1073 | Tue May 18, 2021 8:24 am by Point-Seven-five |
Slotted rear discs in ‘80s Ksby James P | 9 | 887 | Sun May 16, 2021 2:24 pm by Bonzo |
Cleaning K75 Gas Tankby jjefferiesHowto Get Crud oty/off an aluminum gas tank | 18 | 1376 | Sun May 16, 2021 11:40 am by Holister |
Is this bad?by tedmckeyGrungy old front brake upper assembly | 4 | 733 | Mon May 10, 2021 6:37 pm by Point-Seven-five |
K75 cylinder head bolts - buy new or re-use?by DadofHedgehogQuestion about re-using potentially stretched cylinder head bolts. | 9 | 1167 | Thu May 06, 2021 8:36 am by Point-Seven-five |
"RS Style" decalsby KiwiK100 | 13 | 2071 | Wed May 05, 2021 3:09 am by Stickersman |
Rear Shock What Brand??by MartinW | 7 | 907 | Sun May 02, 2021 3:50 am by Suzi Q |
Replacing K100RS-4V front brake master cylinderby QuijoteNOConfusion about compatibility with third party alternatives | 4 | 2140 | Fri Apr 30, 2021 9:44 am by brunodequeiroz |
Auxiliary Pannier Retainers (All proceeds to go to Fire Relief.) $730.00 Raisedby MartinW | 42 | 11885 | Mon Apr 26, 2021 10:44 pm by MartinW |
Side stand switchby Danish bikerMight be placed wrong | 2 | 1044 | Sun Apr 18, 2021 4:14 am by Danish biker |
Painting Issues and report on powder coatingby jjefferiesProblems encountered while painting a K100 | 19 | 1381 | Mon Apr 12, 2021 3:01 pm by SteveWilson |
['93 K75] What is the "overflow cup" mod?by roach374 | 2 | 729 | Sat Apr 10, 2021 3:29 pm by roach374 |
Floating brake disc bobbin wearby 88 | 1 | 956 | Mon Mar 29, 2021 9:17 pm by robmack |
Fairing & Headlight nut clips & boltsby jmailley | 17 | 904 | Sun Mar 28, 2021 2:23 pm by Point-Seven-five |
Need direction on k75 fork heightby rushtkI'm Stuck! | 38 | 1803 | Wed Mar 24, 2021 2:31 pm by Point-Seven-five |
Seat changeby nino | 3 | 889 | Sun Mar 21, 2021 10:40 pm by daveyson |
Plastics use on Kbikesby jjefferiesSide Panels | 25 | 1716 | Thu Mar 18, 2021 9:57 pm by 92KK 84WW Olaf |
Race Tech Cartridge Emulatorsby Point-Seven-five | 28 | 1544 | Thu Mar 18, 2021 8:58 am by Point-Seven-five |
Racetech springs in K1100LT forksby brickrider2the lock ring in the forks | 0 | 655 | Sat Mar 13, 2021 3:44 pm by brickrider2 |
Replacing wheel bearings (16v) without 'fancy' toolsby Bonzo | 23 | 1019 | Thu Mar 04, 2021 6:21 pm by stanthomas |
Will a front end from a '92 K1100LT fit my 16v '90 K100RS?by Bonzo | 11 | 883 | Mon Mar 01, 2021 4:47 am by Dai |
No pressure at hand brake leverby DanT56 | 28 | 1473 | Thu Feb 25, 2021 6:58 pm by DanT56 |
Gas tank linesby hixeey | 5 | 704 | Thu Feb 25, 2021 3:45 pm by MartinW |
['93 K75] Another annoying part number question (sorry)by roach374 | 9 | 880 | Tue Feb 23, 2021 4:41 pm by Mooseman |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
