1Back to top Go down   K1100lt battery negative cable Empty K1100lt battery negative cable Sat Dec 31, 2016 1:43 pm
DeRodster
DeRodster
First up Happy New Year to you all
Strangly enough the login tells me its 4:35 on Jan 1st 2017
Here its 17:35.....still a few hours of '16 left
Can anyone tell me the part nr for battery neg cable K1100lt (92)
Tks
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   K1100lt battery negative cable Empty Re: K1100lt battery negative cable Sat Dec 31, 2016 2:06 pm
Chocolate
Chocolate
Hey!
Normally I build my one earth cable to connect to the gear box and a extra one to the frame under the tank
I don't know the number but this should do.
Battery Ground Neg Earth Cable
Just check the length
Cheers and have a good happy new year,
In Australia they have already
3Back to top Go down   K1100lt battery negative cable Empty Re: K1100lt battery negative cable Sat Dec 31, 2016 2:11 pm
DeRodster
DeRodster
Ta for that
I may try to clean the "green" off and then solder
Failing that it'll ebay or a visit to my local motor
electrical guy
Have a good one
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
4Back to top Go down   K1100lt battery negative cable Empty Battery change done Mon Jan 02, 2017 8:14 am
DeRodster
DeRodster
So. I took my time and the result is good
Having taken out the ABS and Motronic units I found the neg cable was a bit the worse for wear
This no doubt was contributing to the ABS fault issue
https://i.servimg.com/u/f37/18/25/10/19/before10.jpg
A bit of time with wire brush sorted that out and a little work with the Dremel cleaned the connector inside
https://i.servimg.com/u/f37/18/25/10/19/after11.jpg
Then it was out with the gas and a bit of soldering got it sorted
All re-fitted this morning and we're good to go
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
5Back to top Go down   K1100lt battery negative cable Empty Re: K1100lt battery negative cable Mon Jan 02, 2017 11:16 am
6Back to top Go down   K1100lt battery negative cable Empty Re: K1100lt battery negative cable Fri Jan 06, 2017 10:05 am
I'd suggest at some time replacing the failing OEM ground cable with one from an aftermarket auto parts store. Soldering the cable at the lug may compromise its ability to flex at that joint, which will cause it to embrittle and fail in the future. The one I used on my K75 was similar to this:
http://www.canadiantire.ca/en/pdp/motomaster-switch-to-starter-battery-cable-4-gauge-0110961p.html#srp
That type of battery cable would be better than trying to repair a failed OEM one because its lugs have been pneumatically secured to the wire  which can't be done at home and the gauge of the cable is quite large, allowing for large ground currents.
7Back to top Go down   K1100lt battery negative cable Empty Re: K1100lt battery negative cable Sat Jan 21, 2017 10:53 am
DeRodster
DeRodster
K1100lt battery negative cable 20170110
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
8Back to top Go down   K1100lt battery negative cable Empty Re: K1100lt battery negative cable Sat Jan 21, 2017 11:57 am
DeRodster wrote:K1100lt battery negative cable 20170110
Well, that was worth 1,000 words! Laughing
