Number of posts : 7897
When you press the starter button you get voltage. Correct.
When you press the starter button you heard the pump run. Also correct.
When you release the start button the power supply from it dies in 1-2 seconds. Also correct.
But when the engine actually fires the pump connector should still have power but it does not get its signal from the same place. The signal for running the fuel pump when the engine is running is coming from the HES. You need to be sure this signal is also giving power to the fuel tank connector.
The short but cruel test I have with my BMW colleague here is to keep the finger on the start button for an extra 5-10 seconds after the engine fires. If it stays running ok the 95% [not 100%] assumption is that the in tank part is working and to look outside the tank. There are instances on the forum of the electrical boxes pin connectors needing cleaning and also broken wires into the FICE under the seat causing this.
You have a number of Ks so one at a time swap an FICU and an ICU [at the headstock] and see if you get a change.
In both cases I had issues like that swapping these boxes cured it. One as I mentioned a hard to see crack in the FICU and the other well I never found out but put it down to dirty pins on the ICU. On my RT the tank plug checked out fine but there was enough wiggle room for it to break the connection and cut he engine. A reworking tightening up of the pins cured it
If you have similar tanks try a swap of your tank onto one of the other Ks.
The K tank system does sound a curse but in fact when you get used to it its quite easy to work on.
1971 Yamaha 125 YAS-1
