1 Oil/water pump seal and Oil light Sun Jun 27, 2010 5:22 am
swells
I just replaced the water pump and oil pressure switch about seven weeks and 2,600kms. Everything seamed to be fine and I had a trip planed starting on Thurs and getting back Sunday or Monday. While checking the bike over before the trip, I noticed some oil residue laying in the belly pan. I decided to be optimistic it could have been from the fork oil that bubbled and spit back out as I was changing the fork oil last week. I cleaned it up and decided to watch for any further signs of oil during the trip. half way through the trip I decided to head back home. the trip was excellent, 1,351kms, and didn't have any problems until this morning. I noticed a small amount of oil again, this time I could see it was coming from the weep hole. I plan on emailing Max BMW on Monday, but I remembered reading a comment regarding the ceramic seal may take some time to "break-in" and actually seal. so I decided to run the bike a bit more over the weekend and see how things progress. So, I headed out, got some gas and about 9km from home, the oil light came on. So I limped back home. I pulled the cover off of the oil pressure switch and it was full of water from the torrential downpour Friday afternoon. Not sure why this would only cause a problem now, I cleaned the contact and reattached the switch. Well, the light still comes on and I had a single drop of oil in the pan with no other signs of possible problems. I have a brand new water/oil pump and new oil pressure switch, both of which no longer work? I did do a recent oil change, could the filter have backed off or a kink in the rubber seal cause the oil pressure problem?
I guess on a good note, I did get back home without any issue. two days of riding with a total of 16hrs 30 min moving and 3hrs 30 min getting gas and food covering 1,351kms and I didn't have a problem until this morning 9km from home.
I am going to leave the bike until tomorrow, when I may replace the brand new switch with the old one and see if the light still comes on. If it does, what could be the cause? Maybe a blockage in the engine? The water and oil look fine with both a proper amount of each and no signs of cross contamination.
