Go to page : 1, 2, 3 ... 22 ... 43
Topics [0]
Output shaft rivets.by ddunks | 18 | 1345 | 15/04/24, 05:48 pm by daveyson |
Fuel Tank Rubber Strip?by Shep | 5 | 365 | 10/04/24, 02:19 pm by Shep |
Fuel Injector Installationby jjefferies | 5 | 277 | 10/04/24, 10:55 am by duck |
Fuel Pressure Regulator FPRby davemadsenDiagnosising | 7 | 401 | 07/04/24, 08:35 am by charlie99 |
1985 K100RS nagging coolant leak.by RS Rider | 19 | 699 | 06/04/24, 03:05 pm by Two Wheels Better |
Favorite Intake Setup!?by Keedo | 28 | 867 | 06/04/24, 03:39 am by Two Wheels Better |
Carburetor recommendations / thoughts pleaseby tinyspuds | 34 | 1079 | 05/04/24, 12:04 am by tinyspuds |
Flat power band after 4K RPMby P41NLoss of pull after 4k in every gear when accelerating | 1 | 280 | 29/03/24, 03:40 pm by Two Wheels Better |
What the heck is going on?[ 1, 2, 3 ] by Bikesmith | 147 | 5480 | 27/03/24, 03:35 pm by ddunks |
Exhaust headersby Brrapp | 5 | 379 | 18/03/24, 08:08 pm by Two Wheels Better |
OEM Heat Shield Temporary Attach to OEM Exhaust For Provincial Inspectionby Chris350 | 17 | 822 | 15/03/24, 12:38 pm by Chris350 |
K100 Dies after snapping throttle closed at 5000+ RPM, whyby Wirelic | 5 | 501 | 08/03/24, 11:22 am by Wirelic |
Clutch pushrod oil sealby malcolmt | 22 | 8091 | 28/02/24, 06:45 am by SunnyPerth |
valve seals - Valve Sealants - replacementby LifeGuard | 8 | 3103 | 25/02/24, 08:06 pm by Two Wheels Better |
Final drive - taper roller bearingby LifeGuard | 9 | 442 | 25/02/24, 06:22 pm by LifeGuard |
K100 driveshaft lubrification?by katsawa | 24 | 1021 | 20/02/24, 02:57 am by Jordan53 |
Desperate.... K100RT 1985 - startingby Kendallsrengine turns, starts and then stops | 29 | 837 | 15/02/24, 04:20 am by George_Pap |
oil water pump rebuildby Chipper | 2 | 516 | 04/02/24, 06:45 pm by Chipper |
No Fuel Pressureby diceweiss | 33 | 936 | 02/02/24, 01:49 pm by diceweiss |
Oil level sight glass installation?by Jordan53 | 11 | 583 | 30/01/24, 07:37 am by Jordan53 |
Water in oilby Ff223Gutted | 5 | 493 | 29/01/24, 03:06 pm by Laitch |
Water seal in water/ oil pump stuckby SunnyPerth | 2 | 467 | 29/01/24, 02:44 pm by Two Wheels Better |
Rich runnin brickby VERNpoor mileage | 9 | 791 | 05/01/24, 02:38 pm by Laitch |
throttle stays openby mmgee123 | 13 | 864 | 02/01/24, 07:29 pm by Laitch |
Hypothetical issue with Throttle Butterfly Assembly...by Cablebeacher | 11 | 1154 | 26/12/23, 04:20 am by K75cster |
Drive Shaft Problems.by MartinW | 11 | 1081 | 16/12/23, 07:04 pm by Bruce Petterson |
Doesn't Start...by César Santos | 4 | 752 | 11/12/23, 12:28 pm by Dai |
Driveshaft U joint notchiness - how much is too much? '85by Chris350 | 19 | 1431 | 09/12/23, 01:35 pm by RS Rider |
Water pump rebuild very slow leakby KiwiK100 | 3 | 683 | 08/12/23, 04:49 pm by KiwiK100 |
Regular Maintenance?by mmgee123 | 3 | 646 | 07/12/23, 02:03 pm by Two Wheels Better |
Fuel pump working… now what? Bike idles for 2 seconds and dies.by acort | 2 | 578 | 07/12/23, 12:54 am by acort |
Help - Mis-firing 16Vby stanthomas | 29 | 2385 | 05/12/23, 06:24 am by 92KK 84WW Olaf |
Bike diesby Billy | 5 | 738 | 05/12/23, 12:34 am by Rick G |
K100 RS 16V 1990 will not startby th2000125 | 12 | 1126 | 03/12/23, 01:06 pm by th2000125 |
Leaking Fluid?by tjh1985Green-Blue Residue on My Engine | 17 | 822 | 02/12/23, 09:31 am by Two Wheels Better |
starts runs and diesby mmgee123 | 20 | 867 | 27/11/23, 11:29 am by Two Wheels Better |
Radiator Overflow Tank Sight Glass Replacement.by MartinW | 12 | 2484 | 25/11/23, 02:47 pm by 88 |
1985 K100RS - Rough runningby skidogFuel - Sync | 1 | 728 | 20/11/23, 12:33 am by Packo |
maintenance opportunityby tinyspuds | 11 | 829 | 19/11/23, 09:33 am by tinyspuds |
lots of play in the transmission ...got me wondering ....has anybody else experienced thisby charlie99 | 26 | 4004 | 18/11/23, 10:41 am by Beamer |
Missing until engine warms upby davemadsenEngine missing when cold | 15 | 963 | 17/11/23, 09:03 pm by davemadsen |
1985 K100RS. Swing arm bearing play.by RS Rider | 2 | 623 | 12/11/23, 06:56 pm by RS Rider |
2nd gear skipping a littleby TimK100 | 13 | 1477 | 09/11/23, 10:04 am by 92KK 84WW Olaf |
Bubbles in the overflow bottleby KevHBubbles in the overflow | 5 | 890 | 06/11/23, 09:45 pm by KevH |
A little help, Las Vegas area (bike has sat too long)by k100ing | 14 | 926 | 04/11/23, 02:32 am by Point-Seven-five |
How to balance the throttle bodies? (SOLVED)by club_c | 43 | 16270 | 29/10/23, 11:40 pm by Cablebeacher |
High Ratio gears and final drive. Changing gears and bevel box pinion removal.by touchwoodsdenHigh Ratio gears and final drive. Changing gears and bevel box pinion removal. | 13 | 3781 | 29/10/23, 06:33 am by Tranberg |
Weird Clutch issue.by fishboy316 | 13 | 840 | 28/10/23, 09:53 am by fishboy316 |
Issues with timingby svenokStrobe light fails at...bike sound like sh*t | 5 | 915 | 21/10/23, 08:28 pm by svenok |
K100RS - TPS Problem maybe??by GraydoK100RSK100RS - 1986 | 0 | 805 | 18/10/23, 10:05 am by GraydoK100RS |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
