Topics [0]
Fuel dripping from tank when removed from bikeby Rustybottom1985 K100 | 12 | 1678 | Wed Jan 14, 2015 9:49 pm by Holister |
Starter sprag clutch problem.by subby6311986 K100 | 8 | 1941 | Tue Jan 06, 2015 8:17 pm by subby631 |
Fuel tank removal to get at Radiator cap.by werewasi | 9 | 1912 | Mon Jan 05, 2015 12:51 am by werewasi |
K100 piston rings pre and post 1988by Fentible | 5 | 1433 | Tue Dec 30, 2014 12:35 pm by Fentible |
Removing the air filter boxby Alheng | 26 | 6915 | Sat Dec 27, 2014 3:40 am by K75cster |
K75S Balance shaft (output shaft) rebuild - chasing some experienced guruby rawdonballHow to establish required shim thickness for anti backlash gear end float plus ideas as to how motor could have come like this from factory | 12 | 2891 | Mon Dec 22, 2014 7:58 pm by K75cster |
New FPR for the K100/K75by Arlina | 5 | 1631 | Sun Dec 21, 2014 2:42 pm by Arlina |
Thank you FORUM. Problem solved; and I didn't even need to ask the question!by sidecar paul | 16 | 1754 | Sat Dec 20, 2014 1:28 pm by ReneZ |
Underheating cooling systemby jayseabea | 20 | 1943 | Sun Dec 14, 2014 11:44 am by charlie99 |
Difficult to Start when Coldby Tom G | 19 | 3042 | Sat Dec 13, 2014 2:26 am by Tom G |
Trying to get this K running right![ 1, 2 ] by JezWandering idle speed and quitting. | 77 | 4798 | Thu Dec 11, 2014 8:28 pm by Jez |
Oil leakby werewasi | 25 | 2078 | Thu Dec 11, 2014 9:34 am by Two Wheels Better |
Backfire !!by CraigNZ | 27 | 2702 | Mon Dec 08, 2014 7:21 pm by Rick G |
Problems with my driveby AL-58 | 10 | 1542 | Sat Dec 06, 2014 11:08 pm by AL-58 |
Oil (please don't throw rotten vegetables at me)by TIV | 46 | 3047 | Sat Dec 06, 2014 7:21 pm by Inge K. |
Fuel line connectors.by sidecar paul | 10 | 6234 | Sat Dec 06, 2014 6:09 pm by ibjman |
injectors for ford trucks as replacment for K100 injectorsby roys | 16 | 11081 | Wed Dec 03, 2014 7:04 am by Klausmeister |
Dip stick lengthby ssj_Gill | 2 | 1543 | Mon Dec 01, 2014 6:49 am by ssj_Gill |
Clutch slippageby ARTCOLLINSJRClutch slipping in top gear under boost. | 10 | 1334 | Mon Nov 24, 2014 11:04 am by 92KK 84WW Olaf |
Surge/shudder until engine hotby floyd | 20 | 1634 | Fri Nov 21, 2014 6:58 pm by Inge K. |
F D ratios[ 1, 2 ] by werewasi | 65 | 5729 | Thu Nov 13, 2014 9:36 pm by Dai |
Clutch lever rubber boot.by sidecar paul | 3 | 1465 | Thu Nov 13, 2014 6:21 pm by charlie99 |
New oil/water leaksby audibob | 28 | 2045 | Tue Nov 11, 2014 2:20 am by audibob |
Cooling without a radiator shroud or fairingby pjjms | 7 | 2323 | Mon Nov 10, 2014 11:43 pm by Mark K Boy |
New Spark Plugs[ 1, 2 ] by Oliveri | 52 | 5736 | Sun Nov 09, 2014 9:52 pm by Be made |
spark plug question-1985 k100rsby jumpinjimmy | 9 | 4310 | Sun Nov 09, 2014 2:32 am by jumpinjimmy |
Oil/Water Pump - Oil Pressure Switchby Tom GWhat is the function of the second swith near the Oil Pressure Switch? | 1 | 1360 | Sun Nov 09, 2014 12:33 am by Rick G |
K100 '83 2V cylinder head port flowing and flatteningby Martiman | 18 | 3466 | Sat Nov 08, 2014 1:21 pm by 92KK 84WW Olaf |
K100RS Final Drive Mysteryby brickriderwater in case | 10 | 1846 | Fri Nov 07, 2014 4:38 pm by brickrider |
changing oil in the gearboxby brickriderNone too easy | 2 | 1497 | Thu Nov 06, 2014 1:50 pm by 92KK 84WW Olaf |
Crash aftermath....[ 1, 2, 3, 4 ] by Becky | 165 | 6453 | Mon Nov 03, 2014 6:10 pm by Dai |
Gearbox case gasket?by gabriel | 3 | 1397 | Sat Nov 01, 2014 8:22 am by robmack |
Anyone in Oz used Bruno's?by grantf2Spline rebuild/replacement | 4 | 1226 | Sat Nov 01, 2014 3:12 am by gabriel |
Eng stumbles hard on riding..temporarily....idle/revs great.by Andy SEng stumbles hard on riding..temporarily....idle/revs great. | 11 | 1744 | Thu Oct 30, 2014 5:09 am by Rick G |
Exhaust Systemby CraigNZ1991 K100 | 9 | 1643 | Fri Oct 24, 2014 6:27 pm by CraigNZ |
difficulty bleeding brakes after caliper rebuildby jumpinjimmy | 14 | 3916 | Fri Oct 24, 2014 7:03 am by Inge K. |
Wish Me Luck!!!!by jscwerve | 6 | 1501 | Fri Oct 17, 2014 1:03 pm by jscwerve |
Plug wires[ 1, 2 ] by GeorgiaKPlug wire replacement | 52 | 4781 | Thu Oct 16, 2014 4:54 pm by GeorgiaK |
who does this Thermostat think it is anyway?by ssj_Gill | 3 | 1370 | Thu Oct 16, 2014 4:27 pm by charlie99 |
found this in my tankby Holister | 7 | 1549 | Wed Oct 15, 2014 10:27 am by paulespo |
Turbulence in K100 RS gas tank??by jumpinjimmymaybe not a problem at all, but unsure. | 1 | 1317 | Tue Oct 14, 2014 3:56 am by Rick G |
Radiatorby brickridertesting | 1 | 1325 | Sun Oct 12, 2014 3:04 am by Rick G |
My K is not wellby AL-58 | 3 | 1219 | Sat Oct 11, 2014 9:05 pm by Rick G |
'96 K1100RS in Sydney looking for temporary homeby rawdonball | 8 | 1767 | Thu Oct 09, 2014 5:57 am by WandererK1 |
Throttle Position Switchby PucciniNeed Location ID | 3 | 1425 | Sun Sep 28, 2014 8:07 pm by Rick G |
Engine poppingby BarryM | 14 | 2642 | Sun Sep 28, 2014 7:09 pm by Be made |
Purpose of Vacuum switch on rear of throttle bodiesby Fentible | 5 | 2138 | Sat Sep 27, 2014 12:17 pm by Fentible |
coolant flushingby twincarb | 14 | 4411 | Sun Sep 21, 2014 1:18 pm by BarryM |
What in the world is this doodad?by ssj_Gill | 10 | 1539 | Sat Sep 20, 2014 5:38 am by BIKER92 |
Engine weight?by Hover K100K100 engine weight | 7 | 4013 | Tue Sep 16, 2014 3:20 pm by Hover K100 |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
