Topics [0]
Tank vacuumby desperado | 14 | 1566 | Wed Apr 15, 2015 5:12 pm by japuentes |
Split Swing arm bootby audibob | 4 | 1370 | Sun Apr 12, 2015 3:50 am by audibob |
Gearbox swap helpby KlaustheKPutting in a new (used) gearbox | 8 | 1839 | Sat Apr 11, 2015 11:27 pm by KlaustheK |
gearbox out,what nextby k100newbie | 3 | 1972 | Sat Apr 11, 2015 5:28 am by Rick G |
spline lube greaseby k100newbie | 4 | 2049 | Sat Apr 11, 2015 12:59 am by k100newbie |
fuel injector - dead?by DaleRT | 6 | 1497 | Fri Apr 10, 2015 8:32 pm by RT |
cold knockby k100newbie | 7 | 1719 | Thu Apr 09, 2015 11:51 pm by k100newbie |
Noisy fuel pumpby Fentible | 10 | 3473 | Tue Apr 07, 2015 7:40 pm by Rick G |
Synthetic Gear Oilby floydDo it - Do it NOW | 14 | 1962 | Tue Apr 07, 2015 11:28 am by Two Wheels Better |
K75 Oil/coolant pump rebuildby bkhK75Removing pump housing | 6 | 2107 | Tue Apr 07, 2015 8:58 am by Rick G |
Rough Running 1997 K1100LTby mike dPoor Running when riding | 5 | 2579 | Sun Apr 05, 2015 12:57 pm by mike d |
1984-85 K100 ignition coilsby brickrider1984-85 Ignition Coils | 22 | 10102 | Fri Apr 03, 2015 12:09 am by charlie99 |
Increasing oil levelby Point-Seven-five | 16 | 2515 | Thu Apr 02, 2015 11:04 pm by K75cster |
cant lower the idle revsby mr lee esq | 10 | 1448 | Thu Apr 02, 2015 8:51 pm by Rick G |
stale fuelby K7oaks | 22 | 1997 | Thu Apr 02, 2015 5:50 am by 92KK 84WW Olaf |
Unknown noise from engine. 96 k1100rsby jhouse07 | 3 | 1378 | Thu Apr 02, 2015 4:01 am by Comberjohn |
Engine flush advice wantedby audibob | 2 | 1323 | Wed Apr 01, 2015 7:36 am by 92KK 84WW Olaf |
Starter clutchby Rockman | 14 | 1547 | Sun Mar 29, 2015 6:53 pm by kioolt |
oil leak, 85 K100RS, late 84 build dateby arbalestoil weeping from front of pan after 3 yr storage | 7 | 1608 | Fri Mar 27, 2015 5:19 am by Rick G |
Exhaust Header pipe removal. They are stuckby touchwoodsdenStuck Zorst headers | 4 | 2139 | Wed Mar 25, 2015 8:18 am by Dai |
Exhaust headersby td5How to clean | 16 | 1717 | Fri Mar 20, 2015 3:07 am by Fentible |
K1100 Camshaft Alignmentby mike d | 12 | 2123 | Tue Mar 17, 2015 5:04 pm by mike d |
Question about oilpanby Tenox | 4 | 1183 | Mon Mar 16, 2015 8:11 am by 92KK 84WW Olaf |
clutch wont disengageby rsexauer | 8 | 1422 | Mon Mar 16, 2015 6:53 am by rsexauer |
Knocking sound on cold start (video)by BelgianBiker | 13 | 3514 | Thu Mar 12, 2015 5:34 pm by Crazy Frog |
Replacement fuel tank and starting problem.by Moomin_ManLeaking tank... | 7 | 1756 | Thu Mar 12, 2015 7:38 am by Moomin_Man |
POOLING SPARES.by werewasi | 7 | 1555 | Tue Mar 10, 2015 9:16 pm by blaKey |
How do you balance clutch plates??by gabriel | 16 | 2252 | Tue Mar 10, 2015 5:55 pm by floyd |
Exhaust valves - How bad is this?by Holister | 13 | 2853 | Sat Mar 07, 2015 6:06 pm by Comberjohn |
Do I have an older style fuel cap???by svlwolf | 2 | 1338 | Sat Mar 07, 2015 5:04 pm by sidecar paul |
Bleeding Brakesby Tom GBleeding Front Master Cylinder | 11 | 1948 | Wed Mar 04, 2015 8:45 pm by Tom G |
K1100 ignition switchby Packo | 4 | 1474 | Wed Mar 04, 2015 6:41 am by Packo |
Issue after Fuel line replacementby elukrosNo fuel in the Injector rail | 16 | 4419 | Tue Mar 03, 2015 3:33 am by charlie99 |
I'm a lucky Riderby larrikin | 8 | 1384 | Mon Mar 02, 2015 11:55 pm by larrikin |
"Choke" doesnt.by Rockman | 22 | 1950 | Mon Mar 02, 2015 2:39 am by charlie99 |
Time to change the timing chain?by Comberjohn | 40 | 8978 | Tue Feb 24, 2015 8:01 pm by Rick G |
Replacing Water / Oil Pump Sealsby JezHow Shagged is Shagged? | 16 | 1774 | Thu Feb 19, 2015 10:32 pm by Jez |
Spline lube on K100 with mk1 ABS?by Nigel T | 2 | 1274 | Tue Feb 17, 2015 3:21 am by Nigel T |
Clutch centreing tool.by gabriel | 5 | 1467 | Mon Feb 16, 2015 11:08 am by japuentes |
speedo gone u/sby werewasi | 22 | 1567 | Fri Feb 13, 2015 7:21 am by charlie99 |
Clutch Plate thicknessby ShedBob | 7 | 2231 | Mon Feb 09, 2015 4:36 pm by ShedBob |
Sticky exhaust valves.by gabriel | 1 | 1238 | Sun Feb 08, 2015 2:00 am by indian036 |
Hard to start after fuel upby floyd | 5 | 1726 | Wed Feb 04, 2015 6:39 am by 92KK 84WW Olaf |
Fuel Level Indicatorby Tom G | 8 | 1477 | Tue Feb 03, 2015 4:53 pm by Tom G |
starts then diesby mr lee esq | 9 | 1637 | Fri Jan 30, 2015 3:34 am by charlie99 |
Coolant dump.by werewasi | 25 | 2015 | Mon Jan 26, 2015 12:35 am by Rick G |
Engine cutout on throttle off[ 1, 2, 3 ] by Holister | 122 | 10490 | Fri Jan 23, 2015 3:36 pm by wizzard |
Any long term road tests of the FJ27 alternate injector?by Rustybottom | 2 | 2119 | Wed Jan 21, 2015 4:37 am by Holister |
Oil Filter Cover Bolt Strippedby cliverocky | 5 | 1599 | Tue Jan 20, 2015 7:14 pm by TacKler |
Engine overheating??by Holister | 8 | 1560 | Mon Jan 19, 2015 4:55 am by Holister |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
