1Back to top Go down   Fuel Level Indicator Empty Fuel Level Indicator on Sun Feb 01, 2015 5:20 pm
Tom FKR
Tom FKR
G'day All, the yellow beast is now registered and goes well. BUT, the original instrument cluster (86 K100RS) had two low fuel level warning light , at 7l and 4 or 5 l. .Swapped over instrument cluster from a 86 K100RT with only one low fuel level light. The problem is that the two lights do not work on the original cluster and the light stays on permanently on the replacement cluster.Should also mention that the whole loom was replaced from a supposedly K100RS. All you more knowledgeable forumers any ideas. Thanks heaps in advance. Cheers Tom
2Back to top Go down   Fuel Level Indicator Empty Re: Fuel Level Indicator on Sun Feb 01, 2015 5:38 pm
First of all, the cluster with a single 5L warning lamp is the correct one for a -86
(the change was 04/85).
The single 5L and the 7/4L using different sensors and have different PCB's
inside the instrument cluster.
The 7/4L using a thermistor sensor and have the connector at the front left
corner of the tank, the 5L using a float sensor and have a pigtail connector
at the rear end of the tank.
3Back to top Go down   Fuel Level Indicator Empty Re: Fuel Level Indicator on Sun Feb 01, 2015 6:24 pm
Brad-Man
Brad-Man
Later sensor available from BMW.
Fuel Level Indicator Usa-lo10
4Back to top Go down   Fuel Level Indicator Empty Fuel Level Indicator on Sun Feb 01, 2015 7:04 pm
Tom FKR
Tom FKR
Thank you Inge and Brad-Man for your replies. Perhaps the sensor from the LT or even the tank could be installed in the RS. Will experiment and post reply. Thanks again. Cheers Tom.
5Back to top Go down   Fuel Level Indicator Empty Re: Fuel Level Indicator on Sun Feb 01, 2015 7:20 pm
You must combine the tank and sensor as one unit with the correct cluster
with a correct PCB.
But if all clusters have 9 screws you can swap the PCB's if you allready have
a certain tank you wanna use.
6Back to top Go down   Fuel Level Indicator Empty Fuel Level Indicator on Sun Feb 01, 2015 7:54 pm
Tom FKR
Tom FKR
Thank you again Inge, I have a complete tank with correct sensor and cluster that can be used. Will instal and let you know . Thanks again. Cheers Tom
7Back to top Go down   Fuel Level Indicator Empty Re: Fuel Level Indicator on Tue Feb 03, 2015 4:54 am
Hey Tom, good work on getting the rego.
When do you think we are likely to see a brace of yellow Grabau K's on the road? Eden would be a good excuse if the little (big?) brother is up for it.
8Back to top Go down   Fuel Level Indicator Empty Re: Fuel Level Indicator on Tue Feb 03, 2015 5:04 am
hope it goes well for you Tom.  good luck
1987 K100RT  Ex- police
1989 K100LT  Ol' Blue and "Kart" the Kamper trailer.  now KAPUT .
Fuel Level Indicator 10_x_110
9Back to top Go down   Fuel Level Indicator Empty Fuel Level Indicator on Tue Feb 03, 2015 4:53 pm
Tom FKR
Tom FKR
Thanks for that Ed and Gaz, Going to try the replacement fuel sender etc today but a bigger issue has raised its ugly head. 2nd gear is kaput so in the process of replacing  the box from the donor bike. There is a good chance of seeing a pair of yellow Grabau Ks in Eden. Rickmeister is doing a fair bit of therapy on the ankle. Reckon he should also do some therapy on his right wrist. Cheers Tom
