Topics [0]
K100RS 16V Noise (I think from Valves)by adrian_52 | 14 | 1792 | Sat Aug 01, 2015 7:08 pm by haig1968 |
Gearbox faultby rawdonball'skips' in secong gear (momentarily disengages) | 5 | 1612 | Fri Jul 31, 2015 3:10 am by rawdonball |
Remus Innovation exhaust for K100RS 16vby mr grumpy | 42 | 7803 | Sat Jul 18, 2015 1:00 pm by Inge K. |
stanthorpe Rick Gby Packovisit | 8 | 1436 | Sun Jul 12, 2015 7:03 am by Packo |
Gearbox/Final drive oil - K75by bkhK75What to use | 4 | 4817 | Thu Jul 09, 2015 6:25 am by Holister |
staring problemby dwosborn | 2 | 1229 | Tue Jul 07, 2015 9:06 pm by Holister |
Paralever Final Drive Crown Sealby Tfreeze | 4 | 1553 | Mon Jul 06, 2015 9:24 am by mike d |
Fitting rear main seal - wet or dryby Rockman | 9 | 3018 | Sun Jul 05, 2015 9:36 pm by Rick G |
Gearbox & 2nd Gearby TacKler | 3 | 2324 | Fri Jul 03, 2015 9:38 pm by charlie99 |
K100 RS 16vby marknicoJerky transmission | 4 | 1393 | Fri Jul 03, 2015 5:38 am by marknico |
Oil pumpby gabrielK100 oil/water pump | 0 | 1122 | Mon Jun 29, 2015 6:51 pm by gabriel |
No power & Clutch noise when it's engaged. (IUpdate: Fixed)by TheJokerTook a short ride, on a bend I lost power came to a stop. | 32 | 2332 | Mon Jun 29, 2015 6:04 pm by Born Again Eccentric |
16v Motronic non-cat co adjustmentby mr grumpy | 2 | 1498 | Mon Jun 29, 2015 5:23 pm by mr grumpy |
K75 wont run properlyby werewasi | 13 | 1830 | Thu Jun 18, 2015 8:17 pm by Rick G |
oil pressure too low?by k-rider | 12 | 2019 | Tue Jun 16, 2015 4:02 pm by k-rider |
K1 Rear Driveby medobson1 | 3 | 1277 | Tue Jun 16, 2015 11:22 am by medobson1 |
Okay, what now? Totally frustrated FRUSTRATION has returned[ 1, 2 ] by 6stringsK100 engine flooding and will not start | 64 | 4111 | Mon Jun 15, 2015 7:56 pm by robmack |
K100 cut off problemby PVB | 1 | 1223 | Fri Jun 12, 2015 11:44 am by 92KK 84WW Olaf |
Food for thoughtby Rick G | 39 | 2208 | Thu Jun 11, 2015 12:05 pm by Point-Seven-five |
1993 K1100LT woesby krambo | 30 | 4935 | Wed Jun 10, 2015 6:41 am by Rick G |
Lower first gearby floyd | 10 | 1540 | Tue Jun 09, 2015 4:11 am by Rick G |
Boxer twin clutch toolby aladin1 | 3 | 2054 | Mon Jun 08, 2015 4:10 am by dutchie |
Failure to start, and....by brickrider | 6 | 1433 | Fri Jun 05, 2015 11:27 pm by 6strings |
K1100 engine in a K100rsby peteskipslegday | 3 | 1488 | Fri May 29, 2015 4:23 pm by Two Wheels Better |
Valves bent possibilityby VPutinafter some crash | 6 | 1365 | Sat May 23, 2015 8:43 pm by K75cster |
New Problem different area!! Small problem thoughby svlwolf | 3 | 1388 | Tue May 19, 2015 2:51 pm by svlwolf |
Water pump - a new riddle NOW SOLVEDby Howard64180 | 4 | 1343 | Sun May 17, 2015 8:10 am by Howard64180 |
Vacuum line locationby Puccini | 7 | 2505 | Sun May 17, 2015 5:53 am by K75cster |
Cam Chainby bettyswolloks | 4 | 1574 | Fri May 15, 2015 7:29 pm by RT |
Unidentifiable part number for 84 K100RTby aladin1Auxiliary drive shaft O ring | 16 | 1724 | Fri May 15, 2015 4:36 pm by aladin1 |
Assessment of my final drive splines neededby Holister | 17 | 2206 | Fri May 15, 2015 10:01 am by Holister |
Help with swing arm pivot plate removalby audibob | 13 | 4361 | Thu May 14, 2015 12:27 pm by audibob |
Water/oil pump sealsby Howard64180 | 3 | 1391 | Thu May 14, 2015 5:27 am by Howard64180 |
Number 2 cylinder firingby Walla Walla WillieIntermittent firing? | 12 | 1672 | Tue May 12, 2015 1:15 am by brickrider |
K75 Oil/Water pump rebuildby bkhK75Unknown part | 7 | 1631 | Thu May 07, 2015 1:49 pm by gabriel |
replacing k100 rear main sealby k100newbie | 11 | 2694 | Wed May 06, 2015 6:40 am by Rick G |
changing final drive sealsby k100newbie | 11 | 1614 | Sat May 02, 2015 6:05 am by Rick G |
Degreasers and cleaners in the UKby aladin1 | 6 | 1352 | Wed Apr 29, 2015 5:40 pm by aladin1 |
Stuck injectorsby aladin1 | 9 | 1816 | Wed Apr 29, 2015 3:18 pm by the.postman |
Bad throttle pick-up from idle.by WINGLESS | 3 | 1469 | Tue Apr 28, 2015 6:42 pm by WINGLESS |
VW Clutch in your K100by jimz49 | 10 | 5881 | Sun Apr 26, 2015 12:22 pm by japuentes |
Alternator bearing dimensionsby nino | 1 | 1355 | Sat Apr 25, 2015 6:23 am by Inge K. |
Vibration subsequent to clutch malfunction?by Big GVibration subsequent to clutch malfunction? | 2 | 1306 | Fri Apr 24, 2015 7:08 am by Crazy Frog |
Engine rattleby alexanderfitu | 8 | 1978 | Thu Apr 23, 2015 6:28 pm by alexanderfitu |
Centralise clutch plateby FliggyHow do I avoid using specialist tool? | 6 | 1567 | Wed Apr 22, 2015 4:13 pm by Fliggy |
Fuel Consumptionby BigsaxHow far will a full tank go for you? | 25 | 2254 | Mon Apr 20, 2015 6:55 am by Grizzly |
Engine cleaningby aladin1 | 21 | 4503 | Sat Apr 18, 2015 5:29 pm by Crazy Frog |
How old is my bike?by Number14 | 1 | 1189 | Sat Apr 18, 2015 4:00 am by charlie99 |
Tank vacuumby desperado | 14 | 1552 | Wed Apr 15, 2015 5:12 pm by japuentes |
Split Swing arm bootby audibob | 4 | 1360 | Sun Apr 12, 2015 3:50 am by audibob |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
