Topics [0]
Will I need to replace the seal if removing the timing cover?by robmack | 5 | 2476 | Wed Dec 19, 2012 11:47 pm by rosskko |
Injector o-ring sizeby thegreatfordPulling injectors to clean, need to know what size o-rings to pickup to replace them | 7 | 2180 | Wed Dec 19, 2012 5:45 pm by Rjtrucker |
BMW synthetic gear lubeby Themason | 15 | 3771 | Tue Dec 18, 2012 5:39 pm by Themason |
Engine output shaft sealby Crazy Frog | 6 | 2818 | Sat Dec 15, 2012 10:11 am by Tenox |
Twin Exhaust for K100by Dennis | 15 | 6509 | Wed Dec 12, 2012 12:06 am by Two Wheels Better |
Neutral detent ball questionby Tenox | 8 | 2181 | Sat Dec 08, 2012 4:56 pm by Tenox |
K100 oil temp gaugeby klompy the grey brick | 15 | 3467 | Sat Dec 08, 2012 6:19 am by charlie99 |
Early engine finishby Comberjohn | 3 | 1484 | Sun Dec 02, 2012 4:26 pm by sidecar paul |
Final drive variationsby zonenfeile | 2 | 1852 | Sat Dec 01, 2012 3:37 pm by K-BIKE |
Early 85 K100 Vacuum Switchby ibjmanWhat was it's function? | 7 | 4350 | Thu Nov 29, 2012 10:10 pm by ibjman |
(Very) Intermittent Chatteringby zaubertuba | 26 | 2286 | Tue Nov 27, 2012 4:51 pm by Crazy Frog |
Why do we have weird noises?by CommanderKewl | 8 | 1977 | Tue Nov 27, 2012 1:11 am by Themason |
Engine oil levelby Crazy Frog | 13 | 2789 | Fri Nov 23, 2012 7:50 pm by Rick G |
oil filterby lessok100rt | 20 | 2286 | Fri Nov 23, 2012 4:39 am by K75cster |
K100 2V piston deck heightby Dewey V | 0 | 1091 | Sun Nov 18, 2012 11:24 pm by Dewey V |
Engine compatibilityby Rabidchiwawa00716v k100 engine replacement | 10 | 2076 | Sun Nov 18, 2012 5:37 am by Rick G |
Idle speed....by twincarbConfirming the idle speed on the tacho is right... | 34 | 2348 | Sat Nov 17, 2012 12:15 am by K75cster |
ugly photosby klompy the grey brickguess why this is so | 34 | 2236 | Fri Nov 16, 2012 4:58 pm by K-BIKE |
TB adjustment (or not)by ReneZTB adjustment (or not) with anemometer | 7 | 1854 | Tue Nov 13, 2012 11:48 pm by Themason |
Wrong absorber gear wheel for clutch housingby ricketyclik | 1 | 1362 | Tue Nov 13, 2012 2:10 am by Rick G |
The Whistlerby eastern_phoenixUnusual noise ?? | 3 | 1291 | Mon Nov 12, 2012 2:26 am by Themason |
k100 rs wont runby seanzzr | 4 | 1548 | Thu Nov 08, 2012 4:53 pm by charlie99 |
Compression Test after 121,000Kmby Lazyboy | 3 | 1790 | Wed Nov 07, 2012 9:50 pm by Rick G |
Odd noise on Kby graememGearbox/Diff Noise | 13 | 1904 | Tue Nov 06, 2012 1:58 am by graemem |
gas in the oilby Ralph | 23 | 1959 | Mon Nov 05, 2012 10:23 pm by wngnutmv |
1992 K100RS has crazy issuesby Rabidchiwawa007eeek! | 21 | 3408 | Mon Nov 05, 2012 5:14 pm by Rabidchiwawa007 |
hot K100 with oil in coolant onlyby klompy the grey brickK100RS 1984 with a overheat issue | 1 | 1252 | Sun Nov 04, 2012 11:50 pm by Inge K. |
Temp gauge sensor alternateby Farzand Shergill | 8 | 3610 | Sat Nov 03, 2012 2:40 am by Inge K. |
swinging arm/nivomatby big bobk100lt(1987) | 3 | 1311 | Fri Nov 02, 2012 4:17 pm by big bob |
crankcase breather tubeby marten | 6 | 2754 | Wed Oct 31, 2012 1:23 am by Rick G |
Exhaust/silencer clamp.by BooG | 2 | 1210 | Tue Oct 30, 2012 12:50 pm by the.postman |
oil weight causing my leak?by KlaustheK | 3 | 1428 | Tue Oct 30, 2012 12:43 am by KlaustheK |
Injector Cleaner and actuater voltageby K75csterrequired info on injector power | 18 | 2366 | Tue Oct 23, 2012 8:37 pm by yankeeone |
Slight oil seepby DeRodster | 5 | 1548 | Tue Oct 23, 2012 5:48 pm by 88 |
Pressure regulatorby nutheastahwhat does the vaccume do? | 7 | 1890 | Fri Oct 19, 2012 7:26 pm by charlie99 |
Problems with starting "ground not to the starter relay"by suzukii | 1 | 1506 | Wed Oct 10, 2012 1:20 pm by Inge K. |
High idle speed after repairby VPutin1990 K100RS 4V | 2 | 1355 | Tue Oct 09, 2012 6:13 am by Guest |
Output Shaft Sealby JonnyEDrilling A Pilot Hole To Get It Out | 1 | 1521 | Fri Oct 05, 2012 10:18 pm by Toto_jp |
gear box leakby roddyOil leaking from the rear seal of the gear box with the output drive shaft | 4 | 1594 | Thu Oct 04, 2012 2:32 am by Inge K. |
Output Shaft Sealby JonnyEReplacing the output shaft seal | 4 | 1905 | Mon Oct 01, 2012 9:34 pm by JonnyE |
FPR and injectors alternativesby VPutin | 15 | 3728 | Mon Oct 01, 2012 11:49 am by Two Wheels Better |
yet another "won't start" problemby wngnutmv | 5 | 1440 | Sun Sep 30, 2012 12:48 pm by charlie99 |
Clutch cable barrel / nipple holder keeps droppingby 1987k100rt | 25 | 4028 | Thu Sep 27, 2012 6:04 am by gmcq |
Fuel vapor smell is stronger than usual from vent hoses down by the swing arm.by 1987k100rt | 24 | 3707 | Tue Sep 25, 2012 12:05 pm by 1987k100rt |
Clutch problemby mtype1931Looking for help/advice | 31 | 3983 | Mon Sep 24, 2012 8:35 am by K75cster |
Engine Head Boltsby Albyalbatross1 | 16 | 2122 | Sun Sep 23, 2012 6:43 am by charlie99 |
It goes like a train mate....apart from the clutch problems.by bandaid | 2 | 1704 | Fri Sep 21, 2012 4:58 am by bandaid |
K100 Poor Throttle Responseby ToGGoT | 18 | 3987 | Mon Sep 17, 2012 4:34 am by ToGGoT |
K100-RS 16Vby UK_Kev | 7 | 2449 | Sun Sep 16, 2012 9:25 pm by Inge K. |
Drive shaft brokenby Rompunmaan Kunkku | 30 | 3491 | Sun Sep 16, 2012 8:23 pm by Rick G |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
