1Back to top Go down   Question about oilpan Empty Question about oilpan on Sun Mar 15, 2015 2:35 pm
Tenox
Tenox
Did a full oil service (engine, gear and final drive) on my older K100. Everything went OK until the last bolt destroyed a thread on its place... Evil or Very Mad Well I found a longer bolt on my sparebolt bin and it worked well. Allthough I was very carefull these things seem to happen - bike is almost 30 years old and all.
So my question is:
It is one of the three bolts that keep the oilfilter cover on it's place. If I will destroy that thread totally next time I'm changing my oilfilter is it so that I can get the whole oilpan off and those threads are on it? And so it can be fixed or replaced while off.
BMW K100RT Scrambler (86)
2Back to top Go down   Question about oilpan Empty Re: Question about oilpan on Sun Mar 15, 2015 5:17 pm
Yes and yes Very Happy
3Back to top Go down   Question about oilpan Empty Re: Question about oilpan on Sun Mar 15, 2015 5:35 pm
Tenox
Tenox
Well that was easy! Thanks!
4Back to top Go down   Question about oilpan Empty Re: Question about oilpan on Mon Mar 16, 2015 5:48 am
WoodyAUK75
WoodyAUK75
Yep, I discovered this after I fitted an AC Delco oil filter. I managed to get it on, but couldn't get it off (Slightly smaller, tool wouldn't grab). It was a good chance to clean the bottom of the pan anyway.
5Back to top Go down   Question about oilpan Empty Re: Question about oilpan on Mon Mar 16, 2015 8:11 am
If you find yourself doing an oil filter change and do not have the filter removal tool you can take off the oil pan and remove the filter that way. You need to make sure when refitting it that you use the gasket /sealant [not sure which]. It does make a fix of the three bolts filter housing a very easy fix....
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 98,780 miles
1983 K100RS 0011171 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell No 32,600 miles
