1Back to top Go down   found this in my tank Empty found this in my tank Thu Oct 09, 2014 7:59 am
found this in the bottom of my tank when I was replaqcing the filter. It was lying on the R/H side where the fuel guage float is. I'm guessing is off the float arm but what's it for.
Its starting to deteriorate.
found this in my tank 20141010
 found this in my tank Austra12    Fuel:  95 Octane
2Back to top Go down   found this in my tank Empty Re: found this in my tank Thu Oct 09, 2014 8:10 am
Nigel, I think it is off the edge of the baffle where the fuel pump is mounted.
3Back to top Go down   found this in my tank Empty Re: found this in my tank Thu Oct 09, 2014 9:28 am
OK I can see where that might go. Can't see anything about it in the parts diagrams. It won't stay attached to the baffle. Its dropping shit in my tank.... I'll leave it out.
Also there's a small dia rubber pipe coming up from under the rear of the pump about 250 to 300mm long and just sits loose. Is that how its supposed to be. There's a metal pipe u-bend just inside the filler which goes to the drain cup... looks like its supposed to attach onto that??? Is that where it goes?
found this in my tank Fuel_p10
found this in my tank Inside10
4Back to top Go down   found this in my tank Empty Re: found this in my tank Thu Oct 09, 2014 10:05 am
Gaz80 wrote:Nigel, I think it is off the edge of the baffle where the fuel pump is mounted.
+1.....you have two of this, the other one is wrong mounted and seen in
bottom middle of the last picture.
And Your correct about the small rubber hose, it's the breather for the prefilter.
5Back to top Go down   found this in my tank Empty Re: found this in my tank Thu Oct 09, 2014 10:27 am
Inge K wrote:+1.....you have two of this, the other one is wrong mounted and seen in bottom middle of the last picture.
Thanks Inge
The one in the middle bottom of the last picture is the piece I found in the bottom of my tank. So that's not where it goes? I couldn't see anywhere else for it and the manual diagrams don't indicate this part.
Its started to degrade and is shedding particles into the tank. Will I need to replace this or can I leave it out?
6Back to top Go down   found this in my tank Empty Re: found this in my tank Thu Oct 09, 2014 10:36 am
Lower, left corner.....should also be one at the same place in front of the pump.
found this in my tank Pumpe10
7Back to top Go down   found this in my tank Empty Re: found this in my tank Thu Oct 09, 2014 11:16 am
Thanks for that. I'll check it out.
found this in my tank 212902
EDIT: Great. Found where that piece of rubber went... and the other one was on the other side. Breather tube attached.
8Back to top Go down   found this in my tank Empty Looks like part of the Petro Gage Wed Oct 15, 2014 10:27 am
paulespo
paulespo
I have bee waiting for a new petro gage from some ware I guess Germany. I ordered one from so Carolina (Long Story).
But the part you have looks like a part of the petro gage. There a long piece that goes with it. The only reason I know is I had mine out to fix a leak (did not work) besides connecting to the fuel pump it also works the lights on the instrument panel for the 7L and 4L lights.
