Topics [0]
Engine weight?by Hover K100K100 engine weight | 7 | 4033 | Tue Sep 16, 2014 3:20 pm by Hover K100 |
poor bikey! clutch slipping....by Becky | 13 | 1637 | Mon Sep 15, 2014 10:16 am by mike d |
Oil spyglass is full of oil...best way to empty it?by Becky | 11 | 1444 | Sun Sep 14, 2014 6:59 am by charlie99 |
Won't startby bigdavergs | 32 | 2493 | Sat Sep 13, 2014 7:58 am by charlie99 |
Can the air filter be cleaned.by Holister | 18 | 1651 | Fri Sep 12, 2014 2:28 am by Holister |
K100 naked?by Comberjohn | 7 | 2858 | Thu Sep 11, 2014 2:40 am by blaKey |
Oil Leak (Ughh!)by Rickmeister | 2 | 1172 | Tue Sep 09, 2014 1:07 am by Rick G |
Engine 'tapping' noise......by GoosenFun with engines? | 7 | 1350 | Mon Sep 08, 2014 1:54 am by Rickmeister |
Engine output shaftby Flip2Mystery part behind rear main seal | 9 | 1658 | Wed Sep 03, 2014 6:23 pm by rosskko |
16 spline drive VS 20 spline drive?by stilbo | 6 | 1371 | Tue Sep 02, 2014 9:03 pm by stilbo |
Valve springby TricksterPosition | 2 | 1292 | Mon Sep 01, 2014 5:59 pm by Trickster |
Engine / Cooling Systemby Tom GCoolant | 6 | 1338 | Mon Sep 01, 2014 8:00 am by beanoldboy |
Aftermarket fuel level sender replacement floatby duck | 0 | 1322 | Fri Aug 29, 2014 4:46 pm by duck |
Ultrasonic bath fluid.by BooG | 3 | 1282 | Thu Aug 28, 2014 2:37 pm by Maxip2605 |
How many teeth in a k100 gear shifter?by Finnigan | 6 | 1310 | Wed Aug 27, 2014 6:05 pm by Finnigan |
Old gas/new gasby BooGNot good............. | 22 | 1602 | Tue Aug 26, 2014 2:35 pm by BooG |
Transmission Death... Again...by Rabidchiwawa007 | 13 | 2011 | Mon Aug 25, 2014 1:25 pm by Holister |
Nano lubricantsby brickrider | 31 | 2324 | Mon Aug 25, 2014 12:43 am by Be made |
K75S misfiring when coldby john dorman | 3 | 1376 | Thu Aug 21, 2014 10:10 am by john dorman |
Balance paint marks on clutch housing VS clutch assembly?by stilbo | 8 | 2942 | Thu Aug 21, 2014 3:47 am by the.postman |
k1200 exhaustby KafeRacer | 6 | 1928 | Wed Aug 20, 2014 9:46 pm by KafeRacer |
Paint on differential flakingby HellFishTat | 13 | 1325 | Mon Aug 18, 2014 10:47 pm by Rick G |
Cooling System Kleanoutby HolisterWhat's the best product in Oz? | 3 | 1464 | Sat Aug 16, 2014 8:54 am by Holister |
Output Shaftby Rockman | 17 | 2888 | Tue Aug 12, 2014 8:44 pm by Rick G |
Do I have to Drain Coolant?by Finnigan | 2 | 1261 | Tue Aug 12, 2014 5:25 pm by Finnigan |
Rookie question - bellhousingby blimp | 5 | 1276 | Tue Aug 12, 2014 2:50 am by Rick G |
Radiator pipe suckageby Snod Blatter | 46 | 4020 | Sat Aug 09, 2014 8:28 pm by Born Again Eccentric |
Engine Noisesby Point-Seven-five | 22 | 2875 | Fri Aug 08, 2014 11:02 pm by Point-Seven-five |
Seal repairby RTthis is what a leaky one looks like | 4 | 1343 | Tue Aug 05, 2014 12:19 am by rosskko |
8v to 16v engine swap.by KafeRacerlooking for advice. | 21 | 4435 | Mon Aug 04, 2014 9:30 am by Rick G |
Lost compression in back three cylindersby enzo | 33 | 2755 | Sun Aug 03, 2014 4:24 pm by charlie99 |
Fettling my K100 following conversion to K1100 throttle bodiesby Fentible | 11 | 2091 | Wed Jul 30, 2014 3:35 am by Fentible |
turbochargerby tezk100rs | 3 | 1346 | Wed Jul 30, 2014 12:06 am by rosskko |
Radiator capby sidecar paul | 1 | 1287 | Wed Jul 23, 2014 11:26 pm by japuentes |
A busy week ahead?by sidecar paul | 9 | 1378 | Tue Jul 22, 2014 5:17 pm by sidecar paul |
Clear Coating the Engineby ssj_Gill | 8 | 2109 | Thu Jul 17, 2014 6:15 pm by sidecar paul |
Any suggestions chapsby JGT | 25 | 1971 | Mon Jul 14, 2014 2:33 am by JGT |
Fuel Injectorsby jacbucklInjectors | 5 | 1656 | Mon Jul 14, 2014 12:15 am by blaKey |
K75 32:10 Final Drive on a K100by duck | 3 | 1872 | Fri Jul 11, 2014 5:53 pm by orforester |
Swing arm bearing grease retainersby 87100rt | 4 | 1825 | Thu Jul 10, 2014 9:13 pm by 87100rt |
Running in Period?by ssj_GillK100LT | 6 | 1281 | Wed Jul 09, 2014 9:04 am by Avenger GT |
Final Drive - Oil coming from expansion ventby K100LT NottsFinal Drive Oil Leak | 9 | 1851 | Mon Jul 07, 2014 10:47 pm by orforester |
throttle cable 1985 bmw k100by gaylandtcable installation questions | 17 | 4220 | Sun Jul 06, 2014 9:05 am by dutchie |
New Zealand 30th Anniversary Runby mawherasocial rides | 3 | 1245 | Mon Jun 30, 2014 7:19 pm by mawhera |
k75 FD oil sealby RipMcShredder | 3 | 1236 | Sun Jun 29, 2014 7:11 pm by ReneZ |
Smoke on start. Random?by bignews1and21985 K100 RT Smoke on start 8 out of 10 times. | 22 | 3293 | Fri Jun 27, 2014 8:23 pm by AL-58 |
Drive shaft universal jointby robinm | 5 | 3006 | Fri Jun 27, 2014 7:12 pm by AL-58 |
Brake fluid as a bearing cleanerby grantf2Using brake fluid to soak & clean final drive bearings | 9 | 1758 | Thu Jun 26, 2014 5:21 pm by Johnser |
Noisy water/oil pump bearingsby audibob | 4 | 1361 | Tue Jun 24, 2014 3:16 am by audibob |
Driveshaft, diff and splinesby FliggyYour thoughts on my splines | 20 | 2361 | Tue Jun 24, 2014 12:01 am by Rick G |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
