1Back to top Go down   Electrical - i think Empty Electrical - i think Sat Mar 31, 2018 7:57 am
DaleRT
DaleRT
Hi, out for a ride when this happened - about 10min in to the ride
      - the Battery symbol light came on, the Speedo and Tacho needles fell away [stopped working] it also felt like          the engine had a miss. No other lights on the Insrument cluster came on.
   This happened for a 'split second' several times over about 20 seconds.
   I was riding with the parking lights on, i turned them off but it still did it.
   Continued riding [as one would, having no clear evidence or reason to stop] for about another hour with no                issues.
   So where might i start looking ? Im just about to start looking through the our site now.
      Cheers   Dale
2Back to top Go down   Electrical - i think Empty Re: Electrical - i think Sat Mar 31, 2018 9:48 am
Check Fuse #1.  I had a similar thing happen when I had a problem with my heated grips that blew that fuse.
3Back to top Go down   Electrical - i think Empty Re: Electrical - i think Sat Mar 31, 2018 10:28 am
Also check the tightness of the battery cable clamps on the battery, the condition and tightness of the battery's negative cable attachment to the transmission and the tightness and condition of the frame ground attachments.
4Back to top Go down   Electrical - i think Empty Re: Electrical - i think Sat Mar 31, 2018 10:36 am
And the ignition switch........look in the how to section......for dismantle and clean it.
5Back to top Go down   Electrical - i think Empty Re: Electrical - i think Sat Mar 31, 2018 11:40 am
Chocolate
Chocolate
6Back to top Go down   Electrical - i think Empty Re: Electrical - i think Mon Apr 02, 2018 6:42 am
DaleRT
DaleRT
Thanks for the reply's, i do believe it is fixed and here is the journey.
   Obviously i'm missing something, but i didnt find anything in the 'how to section'.
      I checked the electrical connections - battery, earth.
         Looked at .eilenberger. site.
Went with Inge K.  Too the Ignition switch...found this...
Electrical - i think Img_2057
I thought that a clean-up would be good but couldn't get the Grub screw out. So disassembled it as is.
Electrical - i think Img_2058
Used a very small screwdriver to ease out the Tabs of the inner Black section from the White section
Electrical - i think Img_2059
Electrical - i think Img_2060
Electrical - i think Img_2061
These springs do have a life of their own
Electrical - i think Img_2062
Lifting out the base, the spring and steel ball remained attatched to the underside untill i cleared the unit,
then the ball made a run for it. The place was in lock-down so it didn't get away.
Cleaned it all up and reassembled. Keep the unit upright [i read that hint somewhere]
   Helps not to move the key position while its apart.
The inner Black section will only fit one way. The Tabs are different lengths.
Electrical - i think Img_2063
Electrical - i think Img_2064
Cut and resoldered the wires at the base, connected it, went for a spin and... the problem reapeared.
So... in short, the problem was [Well, went for a ride and no sign of the problem yet...] was with the the connection to the wiring harness [under the tank]. There seemed to be a bad connection.
With the ignition on 'Park light' setting, i could wiggle the connector and this would make the lights flick on and off. So i pulled the connector apart, made sure the wire was connected well to the metal socket and made the metal socket a tighter fit around the pin.
Electrical - i think Img_2065
Also, while there, cleaned this end up
Electrical - i think Img_2066
Electrical - i think Img_2067
Electrical - i think Img_2068
So, all clean and with a new gasket, all together, i'm on the road again.
   It was a short ride, Kathy made me this...
Electrical - i think Img_2069
   Cheers   Dale
BMW K100 RS 5/86  104 ea 0886 2123                    0088502
7Back to top Go down   Electrical - i think Empty Re: Electrical - i think Mon Apr 02, 2018 7:26 am
Electrical - i think 112350
DaleRT wrote: Obviously i'm missing something, but i didnt find anything in the 'how to section'.
My fault...I was shure it was one in the how to section Rolling Eyes .....it isn't Electrical - i think 652573 .
8Back to top Go down   Electrical - i think Empty Re: Electrical - i think Mon Apr 02, 2018 7:36 am
DaleRT
DaleRT
Not wanting to sound Cocky, might this be put in the 'How to' section, or change its title to 'Ignition switch' for easy reference?.
9Back to top Go down   Electrical - i think Empty Re: Electrical - i think Mon Apr 02, 2018 9:50 am
From what I've seen on threads here and other brick sites as well as personal experience, I would suggest that the ignition switch should be included as a part of the initial servicing an owner does on every "new" brick.
