Go to page : 1, 2, 3 ... 22 ... 43
Topics [0]
LED Headlight Tipsby naut023 | 0 | 5 | Today at 7:58 pm by naut023 |
I need help please start[ 1, 2 ] by Ribi | 54 | 2022 | Thu Apr 25, 2024 1:14 pm by daveyson |
Original RS Battery dimensionsby ConfusedRS | 25 | 5061 | Tue Apr 23, 2024 2:24 am by Two Wheels Better |
I need a workaround to replace my fuel sender on a 85 K100RTby BubbaLinks | 5 | 479 | Sun Apr 21, 2024 4:15 am by dbier |
Temperature sensorby davemadsenMeasuring | 23 | 596 | Wed Apr 03, 2024 10:51 pm by Point-Seven-five |
Another Signal Light issueby QuietLTSignal quit when I stop. | 1 | 288 | Thu Mar 28, 2024 3:26 pm by Laitch |
51913 battery in 8v K100by Snod Blatter | 23 | 1607 | Mon Mar 25, 2024 6:09 am by LifeGuard |
Battery woes - solvedby Born Again Eccentric | 5 | 613 | Tue Mar 19, 2024 5:15 am by 92KK 84WW Olaf |
hydraulic rear brake switchby arbalestmechanical to hydraulic rear brake switch conversion | 8 | 425 | Wed Mar 06, 2024 9:03 am by Point-Seven-five |
GPI screen gremlinby KiwiK100 | 7 | 486 | Thu Feb 29, 2024 7:52 am by charlie99 |
Bouncing speedo needle at idleby KiwiK100 | 7 | 519 | Fri Feb 23, 2024 9:19 pm by Dai |
Sudden no start with starter button, where to check next?by boostd4 | 25 | 3835 | Sun Feb 18, 2024 12:17 pm by pwfree |
1986 K100RS wiring harness needed!by rreifelLooking for a replacement for the original wiring harness | 5 | 485 | Sat Feb 17, 2024 12:04 pm by duck |
OEM Speed Sensor - Acewell - BEP 3.0by GeoffP63Speed not showing | 6 | 2038 | Fri Feb 16, 2024 12:56 am by Glyn |
Fuel gauge erraticby GeorgeDaBikieFuel gauge erratic | 0 | 366 | Thu Feb 15, 2024 10:57 am by GeorgeDaBikie |
BEP 3.0 installation questions.by vigdel78 | 20 | 10517 | Tue Feb 13, 2024 11:29 am by robmack |
Dry test fuel pumpby tinyspuds | 6 | 587 | Sat Feb 10, 2024 8:26 pm by caveman |
Replacing the neiman cylinderby 49BMWK1 | 4 | 451 | Fri Feb 09, 2024 2:04 am by 49BMWK1 |
An alternative way to get the Gear Position Indicator to work on an aftermarket speedoby Jacod | 8 | 4902 | Sat Jan 20, 2024 9:13 pm by Jacod |
K75, interesting electrical phenomenaby jjefferies | 7 | 665 | Sat Jan 20, 2024 1:26 am by Laitch |
How to get a cheap eBay Speedo to workby JacodAll of it works but the TGPI To hopefully save any future tin bums some time I have explained below how I managed to get the speedo to work. | 39 | 16152 | Fri Jan 12, 2024 11:50 pm by robmack |
Hall Sensor Plug pin descriptionby Rolf E | 15 | 596 | Fri Jan 12, 2024 7:17 am by Rolf E |
Mystery plugs in the relay boxby Jordan53 | 4 | 545 | Wed Jan 10, 2024 8:59 am by Jordan53 |
Can coils die of old age?by Clintinzso close to firing this thing up | 24 | 1754 | Sun Dec 31, 2023 12:59 pm by Two Wheels Better |
Remove ABS module and wiring?by Nealchaykin69Turning 1985 K100rs into a cafe racer | 19 | 776 | Sat Dec 30, 2023 2:49 pm by Laitch |
restoration of the fuel sender ...a work in progress so farby charlie99 | 40 | 2497 | Fri Dec 29, 2023 9:18 am by yamaguzzi |
No spark nor spray from fuel injectorsby Harry.Dip | 8 | 749 | Fri Dec 29, 2023 3:47 am by Laitch |
fuel gaugeby GeorgeDaBikieWill the sender unit run a fuel gauge | 20 | 1489 | Mon Dec 25, 2023 10:27 am by daveyson |
Axel Joost Neutral Switch + M.unit and clutch switch woesby Harry.Dip | 19 | 1145 | Sat Dec 16, 2023 11:12 pm by daveyson |
Trouble Starting & Runningby Keedo | 35 | 1409 | Mon Nov 27, 2023 6:03 am by 92KK 84WW Olaf |
Alternator[ 1, 2 ] by fishboy316 | 71 | 3210 | Sat Nov 18, 2023 9:45 am by Dai |
Batteries.. again.[ 1, 2 ] by JaseYPKSmaller Batteries! | 56 | 5747 | Fri Nov 17, 2023 8:48 am by Tranberg |
Spark plugsby Holister | 29 | 4258 | Tue Nov 14, 2023 12:23 am by Point-Seven-five |
BMW K75 dies out sometimes and wont start for a whileby PhillipRamboBMW K75C issue | 25 | 1426 | Sat Nov 04, 2023 12:53 am by moriarti |
Plug wire options?by BespokeVillainy | 11 | 2190 | Fri Nov 03, 2023 11:25 am by redrockmania |
windscreen windshield motorby attituderepair of windscreen motor | 1 | 713 | Thu Nov 02, 2023 6:29 am by Dai |
Hall sensors, Coil or just a loose/bad connection?by SunnyPerthvery intermittent drop of tachometer and power | 7 | 1006 | Wed Nov 01, 2023 9:49 am by SunnyPerth |
Suspected Electrical Issueby Robert CrispBike won't run | 6 | 914 | Sat Oct 28, 2023 7:26 pm by daveyson |
Changing speedo from MPH to KPHby coopz1985 K100RS | 16 | 2688 | Thu Oct 26, 2023 4:14 am by Tranberg |
Hall effect sensor HES tester test LEDby Dai | 3 | 947 | Wed Oct 25, 2023 10:32 pm by Dai |
Fuel pump cutting out and a bonus mystery...by KEVVYMETAL | 10 | 1197 | Tue Oct 24, 2023 1:13 am by j1s1 |
'92 K75 Intermittent Alternator (light)by jjefferies | 33 | 1145 | Sat Oct 14, 2023 5:56 pm by Laitch |
85 K100 Speedometer Issuesby Chris350 | 8 | 1427 | Tue Oct 03, 2023 3:31 pm by WarrenD |
Gremlinsby Pete RileyElectrical | 5 | 868 | Sun Oct 01, 2023 9:41 pm by Arlina |
Substitute HES pickup plateby Dai | 25 | 1810 | Wed Sep 27, 2023 6:55 am by Dai |
1985 K100RS. Newer style coil problem?by RS Rider | 4 | 952 | Sun Sep 24, 2023 5:28 am by RS Rider |
Strange Gear Outputby TheplayVikMight have overstretched voltage a bit | 5 | 1108 | Mon Sep 11, 2023 12:46 am by Point-Seven-five |
Starter no crank[ 1, 2 ] by OK1987LTNo crank, no neutral light and gear position indication. | 57 | 2122 | Tue Sep 05, 2023 7:07 am by OK1987LT |
Fuel light unit[ 1, 2 ] by Crazy Frog | 59 | 13412 | Mon Sep 04, 2023 8:34 pm by TacKler |
While the bike sits it mysteriously drains my batteryby TSBT | 31 | 5843 | Mon Sep 04, 2023 6:23 pm by VEKA4 |
Topics [50]
Users browsing this forum: naut023Permissions in this forum:
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
