Number of posts : 11688
Dai wrote:Brief explanation, because I'm damned if I'm going into the thermodynamics of it!
The air box takes air from the air intake and both filters it and acts as a very short term reservoir. From there, it goes through the AFM to the plenum chamber. The AFM does exactly that; it measures the air flow demanded by the engine and passes the data on to the FICU to determine how much fuel is needed. The plenum chamber acts as an equalising chamber for the four intake trumpets (venturi) because the cylinders pull air at different times. Each of those venturi acts as a restriction in the air flow which accelerates the air into the cylinder and jams more air in than would be possible without the venturi. Google 'venturi effect'.
Anyone got anything to add to that very, very brief description?
yes ,
just to mention that the size and location of the air box (in the system ) reduces induction noise very markedly
a requirement to attempt to satisfy the noise regulations across all manufacturers , in some cars you will find a small box attached to the inlet path after the air cleaner ,. which is designed just for that reason , but other wise seems of little value , until you remove it and hear the change in induction noise, it is quite apparent .
the intake trumpets , commonly called velocity stacks are designed to affect the peak induction velocity at certain revs (as dai says , to do with cylinder filling ), and can often be designed to improve performance of the motor at the designed rev range expected , so enhances the whole system if designed correctly , like exhaust but in reverse
the length of the air induction system , from valve seat to air inlet snorkel opening can also enhance low end engine efficiency and torque,
